Question about Motorola Mobility RAZR V3
Motorola razor V3
When i flip open my phone it dials 6 and 4. i cant doanything else and sometimes it switches the volume to 6 and 4. how do i fix it?
    Scholar:
  • 87 Answers
Honestly, it sounds like the Keypad Flex, or Keymat with Flex cable has been exposed to moisture. I would recommend taking it or sending it to a service center, but if you want to try yourself... here are some instructions to help you get moisture corrosion out of the phone.
I'm betting if you open it up, you will find corrosion in the main cable channel on the mother board as well as on the end of the cable itself.
I work a repair center and perform the functions below daily, but you must understand that you open the phone at your own risk.
With a T6 torx screwdriver, remove the two screws you will see under the battery cover towards the bottom of the phone. Once the screws are removed, gently lift up where the battery contact terminals are, GENTLY. The main flex bends and plugs into the board right there. With a small flat tip screwdriver, unplug the main flex from the motherboard. Once this is unplugged, work that back piece slowly until it comes off. The main motherboard will come with it.
I would just about bet you will see some corrosion where the main flex plugs into the board. Use some rubbing alcohol and a toothbrush to clean both the plug and the end of the main flex. Let dry completely, reassemble and see what you get.
You may also have some corrosion in the top 1/2. You can get into it by removing the 4 rubber bushings at each corner around the main inner lcd, and then remove the 4 T5 torx screws. Once the screws are removed, close the phone and hold it looking at the outside screen with the camera on top. Start working the outer cover off at the top by the camera lens. With the screws out, it is just snapped on.
Once that outer cover is off, you will see upper plug for the main flex on the upper left. Unplug this and clean the plug and the end of the flex the same way, rubbing alcohol and toothbrush.
Preferably 91% rubbing alcohol because it evaporates cleaner.
If this isn't something you want to try yourself, I recommend Wireless Unlimited - Cell phone and computer repair.
www.wirelessunlimitedinc.com
www.myspace.com/wirelessunlimited
423-913-0488 10a-6p M-F EST.
If you mail it to them, they can have it fixed and back in the mail to you the same day they recieve it.
Please remember to rate. Thanks
Posted on Sep 04, 2008
Display faulty
hi :) motorola K1 is a flip phone,when open flip no display,that mean phone ribbon was spoil.pls send for mobile technician to change a new ribbon. pro will solve.
Jul 06, 2010 | T-Mobile Motorola Razor V3 Custom Cell...
I have a motorola razr v3 that i hear fine out of but others cant hear me
You will have to get your cellphone repaired that is the only solution to fix this problem.IF it is under warranty then please get it replaced.
You can try taking the phone apart if you want and clean and reattached the connections to the speaker in the phone.
Good luck,
Please don't forget to rate the solution.
Mar 30, 2008 | Motorola Mobility RAZR V3
Phone start dialing when you open,this is a razor go phone with a real sim
Your phone keypad liquid ingressed or flex connectors to main board liquid ingressed check and clean up,try to swap another flip,if ok,that keypad faulty.replace it,if not check 2 IC small, near the connectors keypad could be corrosed clean them,hope to solve your problem.
Van
Aug 15, 2009 | Motorola Mobility RAZR V3
Razor V3
Take it to the service center, the keyboard cable got broken or worn.
May 03, 2008 | Motorola Mobility RAZR V3
Speed dail
you can try master resetting the phone then try it again.
Mar 09, 2008 | Motorola Mobility RAZR V3
Screen went black on my motorola razor
Nothing you can do about that but replace the whole flip assembly or the LCD on the flip. Another cause for this is a bad component on the main board, probably faulty or a blown capacitor. Liquid can also cause this problem, if any rain or condensation seeped through your phones keys then your lcd will fail. So your only fix is to replace the main lcd or flip assembly, you can also take it to your carriers repair center and have the phone swapped if they cant fix it for you. Good luck.
Jan 29, 2008 | Motorola Mobility RAZR V3
Will not hold a signal
you should have the phone replaced from the provider......
Jan 03, 2008 | Motorola Mobility RAZR V3
ALL BUTTON OF RAZOR V3 FROZEN
That happened to my phone and I had to return it, there was no fix.
Sep 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
63 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
