Question about Panasonic Panafax UF-550 Plain Paper Laser Fax
The zero does not work....HELP! - Panasonic Panafax UF-550 Plain Paper Laser Fax
    Genius:
  • 2,120 Answers
You need an operation panel. ($100.00) If you're real handy, you can un-solder one of the unused buttons and replace the zero button with it. They're all the same.
Posted on Sep 05, 2008
Hp officecalc 100
As a get around, use the double zero key then back delete one.
Mar 06, 2014 | HP Computers & Internet
The Sub Zero bottom dram freezer has stopped working
HI,
What does you freezer do? Does the lights work and fan work? The fan works with the cold control, if the light switch fails the unit will defrost in about 3 - 4 hours, will remain cold though, just not frozen. I need more information to direct you correctly.
I am here to help
Aug 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Hi I am having trouble getting my DVD player to work with my RCA F27440 TV. It worked fine with my other TV. Can you help?
If there is not a TV/Video button on the TV I believe that RCA uses channel 00 (zero zero) for the video input.
Jan 04, 2009 | RCA F27440 27" TV
Help and thanx for your help
try 0000(4 zeros) or 000000 (6 zeros) or full zeros ...
you can find the IMEI of your cell by giving *#06# ... note the IMEI number and tell me i will provide you the unlock code
Sep 12, 2008 | Nokia 3230 Cellular Phone
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
Phone lock code
  if this code is  for ur  phone  only then  the  only possible solution is that .... u need to go 4r phone reset ..   TAKE care  u need to take the data back up  before  going 4r phone reset ............  concern sonycare center   4r reset  process ...
Sep 16, 2007 | Sony Ericsson T610
Panasonic Panafax UF-550 Plain Paper Laser Fax Logo
24 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
