Question about Olympus Stylus 710 Digital Camera
D: 5f08,5f0a,5f08,5e02 When i press the power, the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08,5f0a,5f08,5e02". what does this mean??? can you help me fixed this one??
  • xxxazngrl Sep 20, 2008
    something wrong with my camera..and this is how it happen: I was about to connect my camera on my computer with the USB and when i did, this screen shows up and it says this on me Camera:
    D :
    5f08
    5f0a
    5e02
    5f08
    5e02.
    it shows that with a blue background on my Camera. Can Somebody Help me?
  • Anonymous Sep 25, 2008
    al encender la camara, esta prende y el lente comienza a moverse y no enfoca, luego sale una pantalla azul con unas letras blancas que dice
    D:
    5f08
    5e02
4 Suggested Answers
SOURCE: 5f08, 5e02 error
My Stylus mju-mini was doing this and I found the answer on expansys. Just hold the camera so that the lens is facing up when you turn it on. Works every time for me!
Posted on Mar 11, 2008
Bubbabear64
  • 2794 Answers
SOURCE: D: 5f08 5e02
You should have a technician look at it.
You might be able to reset it by taking the battery back out and putting it back in again.
You could try it as well by plugging it into an electrical outlet. That might reset the error message as well.
Posted on Jun 14, 2008
When you turn the camera on, try it with the lens facing upwards and it should work, I had the same problem. Hope this helps :)
Posted on Jun 26, 2009
Blurry webcam
Many laptop computers come equipped with a small web camera assembly mounted above the LCD screen. Like any other camera, these webcams use a lens to take pictures. Over time, it is possible for this lens to become dirty, especially if you have touched it a few times. You can quickly clean the lens and get the unit back to taking crisp pictures.
1.Take a microfiber cloth and gently press it to the lens of your laptop's web camera.
2.Gently rub the lens of the web camera with the microfiber cloth. Be sure that you cover the entire surface of the web camera's lens.
3.Open your web camera program when you are finished and take a picture to test the quality of the webcam. If it is still blurry, close the program and repeat steps 1 and 2 until the web camera is no longer blurry.
Sep 09, 2011 | Cameras
Pictures are appear blurry when reviewing them. I focus the camera object appears clear after I snap the picture it becomes blurry as it is being save for review.
Question : Why are my pictures out of focus (blurry)? Answer : This problem can occur for one or more reasons. Here are some common causes and suggested solutions.
  • The lens is dirty. Use a soft brush to remove dust and dirt. Wipe the lens gently with a soft, lint-free cloth or an untreated lens-cleaning tissue. Do not use cleaning solution unless it is designed specifically for camera lenses.
  • The subject was too close to the camera. Make sure that you are far enough away from your subject. Each camera has a recommended distance for normal, telephoto (zoom), wide-angle, and close-up pictures.
  • The subject was not within the effective range of the flash. Each camera has an effective flash range.
  • The camera did not focus or expose the picture correctly. For the best possible pictures, press the shutter button halfway and hold. When the Ready light or framing marks turn green, press the shutter button completely down to take the picture.
  • The LCD screen Preview feature was not used to take a picture in Close-Up mode. Always use the Preview feature in Close-Up mode to confirm focus and to frame the subject properly. If the Preview feature is not used, the LCD will not display an accurate view of the subject.
  • The subject or camera moved. Hold the camera very steady when taking a picture, or place the camera on a flat, stable surface. You may want to consider using a tripod or monopod.
Dec 08, 2009 | Kodak EasyShare Z740 Digital Camera
5f08, 5e02 error
Jun 22, 2009 | Olympus Stylus 710 Digital Camera
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08
i have the same problem with my camera it show 5foa 5f08 5e02 with the blue screen
Sep 24, 2008 | Olympus Stylus 710 Digital Camera
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08 5e02
this is the most common problem with the olympus cameras the lens has been knocked and by you pulling on the lens it sounds like you have done some damage to the motor that bring the lens in and out thats why its making that noise what you needed to do was move the lens either to the left or the right you will no when its fixed because the lens just pops out and the camera will be fine this works every time i just hope you havnt done to much damage alredy goodluck
Sep 21, 2008 | Olympus Stylus 710 Digital Camera
D: 5f08 5e02
Jun 14, 2008 | Olympus Stylus 710 Digital Camera
5f08, 5e02 error
all these ppl are wrong i just fixed my moms camera with the same problem ur lense gears are off track simply turn ur camera on and as the lense comes out pull it till it comes all the way out dont be scared to pull and wiggle it a lil bit imean what have u got to lose . like that guy said he put it in his pocket and it came out broke its cus the camera turned on in his pocket and couldnt come all da way out and got jamed
Nov 17, 2007 | Olympus Stylus 710 Digital Camera
Blue screen error code
the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5f08 5e02". what does this mean??? can you help me fixed this one??
Oct 13, 2007 | Olympus Stylus 700 / 700 Digital Camera
Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Frank!!
Oct 07, 2007 | Olympus Stylus 700 / 700 Digital Camera
Olympus Stylus 710 Problem with lens
Turn on camera. Blurry pic. Wirly grinding noises. Blue screen.
Codes on blue screen:
5 f 0 8
5 e 0 2
5 f 0 8
5 e 0 2
Sometimes smacking the **** out of it fixes it. Today it doesn't seem to do the trick any more.
Suggestions?
Sep 07, 2007 | Olympus Stylus 710 Digital Camera
Olympus Stylus 710 Digital Camera Logo
106 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
