Connecting coax to my DVD/VCR combo
  1. There are no coax connectors on my new DVD/VCR unit, how do I send the coax feed into my new unit then send it out to my home theater receiver
  • charlie7777 Sep 05, 2008
    1. I solved the problem myself, thank you for your response.
  • Jim Franks May 11, 2010
    Where does the coax originate? A cable box, outlet or a satellite receiver?
    Scholar:
  • 141 Answers
For the DVD portion, you need to use either composite, component, or possibly S-Video or HDMI. DVD players do not utilize coax, since they do not incorporate tuners. However, since you have indicated it is also a VCR, it should have a coax input/output for that. perhaps it is a player only and doesn't have a tuner? But I have never heard of this in a combination unit. At any rate, if it truly does not have a coax input, then you will have to leave the coax connected directly to your TV and use the above mentioned connections between the home theater, TV, and DVD/VCR unit. Audio between the DVD/VCR and home theatre, and video between the DVD/VCR and TV
Posted on Sep 04, 2008
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
I have a rf modulator i dont no where any thing goes i tryed i just dont understand it i just brought a dvd and vhs to gether
alot of DVD/VHS combos have a built in RF modulator. Look for a coax (screw threads) output on the unit and it should be labeld either DVD/VHS OUT or just VHS OUT. If it does not have a combo out then you will need to use the seperate RF modulator.
Your combo unit should have a set of yellow red and white jacks that are labeled DVD & VHS OUT. Connect these yellow red and white to the yellow red and white on your RF modulator, then connect the coax (screw threads) out on the RF modulator to the coax jack on the back of your TV. There is also typically a swich for channel 3 or 4 on the RF Modulator, make sure you TV is on which ever channel you have that switch set to. If your RF modulator has a power light on it, it will usually not come on until your DVD/VHS is sending a signal through it and it is connected properly.
If you have an antenna or cable box, your RF moudulator should have an Antenna or Cable input jack on it that you can use.
May 05, 2011 | Magnavox DV220MW9 DVD Player VCR
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
Cable/ant. hook-up
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
Sep 09, 2008 | Philips Magnavox DVD/VCR Dual Player
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Hooking up a dvd/vcr player
The easiest way to connect the unit is via coax. You can come out of your satellite receiver via the "Out to TV" on the back of the receiver to the "In from Ant" on your DVD/VCR combo. You can then connect another coax from the "Out to TV" on the DVD/VCR combo to the "Ant/Cable" input on the back of you TV. Make sure the satellite receiver and the vcr are both modulated to the same channel, normally channel 3.
Dec 31, 2007 | Emerson EWF2004 20" TV
Hook up vcr
yes, you need to use an Audio/Video cable (red, white, yellow) to hook to the TV. I've never seen a VCR that doesn't have coax connectors for the antenna input and TV ouput, but maybe the new ones are starting to leave that out. Normally, you run the antenna or cable coax into the VCR's input, then run another coax from the VCR output to the TV's input (or use an A/V cable)
Dec 20, 2007 | Sharp VC-A420U VHS VCR
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Connecting VCR/DVD combo
If you are able to you can connect to the RF connector (F Type Conncetor) on the TV. This should work. The layout is from the VCR (RF to TV) to the TV antenna F type connector from your Cable box to the Antenna in of the VCR that way you have cable through the VCR, and access to you VCR and DVD all controlled by the Cable and VCR remotes (set TV to Channel 3, set VCR to Channel 3) and use the Cable box as the tuner, Use the TV remote to switch between Cable and VCR inputs then use the VCR remote to switch between the VCR and DVD input.
Sep 20, 2007 | GE 25GT516 TV
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
