Question about NEC MobilePro P300 Pocket PC
Not recognize the PC Card Expansion Jacket after a soft reset
Why won't my P300 recognize the PC Card Expansion Jacket after a soft reset?
    Master:
  • 903 Answers
Make sure the P300 has completed the boot process before attaching the PC Card Expansion Jacket. This will ensure proper detection.
Posted on Sep 15, 2005
  • zoe walton Nov 24, 2010
    what is pc card expansion
Memory card not working
try to put in card reader and connect to PC,if PC recognize your memory card try to take backup of your file in card using icare card pro software..then format the memory card... even PC also not recognize your memory card is dead...
May 14, 2012 | BenQ-Siemens Benq E71 Mobile Phone Cell...
Message says - memory stick not inserted
Dear,just format the card with computer through a card reader and insert the cardinto fone then format the card by ur fone and then check, if problem presists then ur fone's card jacket is not working so then you will need to go to a certified mobile fone repairer to get changed your fone's jacket. its not very expensive..thanks
Apr 06, 2010 | Sony Ericsson Walkman W810i Cellular Phone
It does not recognize an 8gb sd card in storage expansion.
Your netbook should read SDHC(over 2 GB capacity) memory cards. The problem might be either the card slot driver, Which you should download if a newer one is available. Or in case you format the SD as DOS then it will only have around 2GB of space, You should format it as DOS32 or NTFS so you get the full capacity for the SD card. Some pirated rather cheaper memory cards have a lower actual capacity. With some compression technique the capacity presented is higher than it actually is. If you format it then it will show the real capacity. hope that is not the case!
Good Luck!
Nov 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Why won't my p300 read my sd card?
Hi
What is the memory capacity of the card? if its more than the required sd card memory capacity compatible for the phone it may not read it. normally this phone supports up to 1gb sd card
May 10, 2009 | NEC MobilePro P300 Pocket PC
Expansion card
Has this card worked before in your Palm?
Jun 30, 2008 | Palm Tungsten E2 Handheld
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
Zire 72 does not recognize the SD card
Have you used this card long and what size is it?
Jul 11, 2007 | Palm Zire 72 Handheld
My P300 won't sync when it is attached to the PC Card Expansion Jacket and inserted into the USB Cradle?
You can prevent this issue by making sure the P300 is turned on before putting it in the cradle. This is limitation of the current operating system.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
Cannot see any SD card in expansion slot
The first thing to try is a soft reset while the card is inserted.
Sep 11, 2005 | HP iPAQ H2210 Pocket PC
NEC MobilePro P300 Pocket PC Logo
555 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
