Question about Mitsubishi WD-52525 52" Rear Projection HDTV
WD-52525 Red lamp Indicator
I have a Mitsubishi WD-52525.
Red lamp indicator was on and TV wouldn't come on. Ordered and installed new lamp.
Plugged back in and green inicator lamp flashed for a about a minute and stopped
Turned TV on & there was click and fan noise. Then the lamp came on for about 9 secs, 2 mins later the red lamp indicator light came back on. At no time during the process did I get pix or sound.
The error code flashed 34 when held in the device menu buttons
Capacitors? Lamp ballast, or Light Engine? Combo? Something else?
  • RIXSTER Sep 05, 2008
    I AM HAVING SAME PROBLEM, BUT SOMETIMES WHEN I TURN TV ON, I SEE FLASHING HORIZONTAL COLORS. I TOO HAVE TRIED NEW LAMP. ALSO AT ONE TIME, A MESSAGE CAME UP SAYING 'CHECK CONNECTIONS OR POWER. THE CONNECTIONS FOR RGBHV OR YPrPB MAY BE INVALID.' I CHECKED CONNECTIONS, BUT FOUND NOTHING. ALSO SAW MESSAGE SAYING NO SIGNAL, BUT COULDNT READ THE REST CUZ OF THE FLASHING COLORS. AT OTHER TIMES ITS THE SAME.(RED LAMP LIGHT ON WITH NO PIX OR SOUND)
  • CB23 Sep 05, 2008
    I talked with Mitsubushi customer service & they acknowledged they have had a problem with capacitors on my model but that is applies to the continiuos blinking green light and that my problem with red light indicator after replacing with a new lamp and error 34 was something different and other than giving me a service rep number they were unwilling to anything.
  • Mitsubishi Master
  • 8,617 Answers
Usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
I have a Mitsubishi digital WD-52525, and the "lamp" indicator is illuminated in red. Can I buy a new lamp and replace it myself?
If you have a red led solid. check the fans and make sure they work. Sceond push both input and menu and see what the blink code is?
Jul 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My Mitsu 52525 lamp indicator went solid red. I
sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
May 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp Indicator is Red
a 41 error code for a short is usually caused by the power PWB. The power board will need to be replaced
May 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Its much more likely that your getting a 34 error which is a lamp abnormality vaused by defective capacitors on the power board. You can get the V26 DLP power PWB repair kit at the following link that should repair the issue. Chances are your old lamp is still good.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
May 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Lamps have been known to burn out the power supply to the DM assembly. If there is no visible damage to the lamp, your problem may be the power supply or the board. Good luck.
Oct 09, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
377 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
