Question about Sony Cyber-Shot DSC-W1 Digital Camera
Help, White spots on photos with W1
I just downloaded my memory stick and while viewing the shots, I noticed that some of them had white spots. They were in the firm of circles and varied in size , position, intensity, and number. I was using a W1 on P mode, ISO 400, inside with flash. Is this a flash thing or is something starting to go wrong. I haven't used it that much, but this is the first time I did a lot with the flash. Any ideas are appreciated. TIA, John
    Master:
  • 551 Answers
If they're not showing up without flash my guess is dust or pollen in the air that is so fine you don't see it under normal light. Like the dust you see in a ray of sunshine but can't see normally. Dust on the lens will be dark not light.
Posted on Sep 15, 2005
    Master:
  • 551 Answers
Could be dust reflecting the flash. Water droplets also do it. Here's an example from an indoor trials where they had little RC cars on a dirt track next to the trials. The RC cars kicked up dust. The flash just bounced off the particles. This is an 828 with a Metz flash with a pocket bounce/diffuser on top. With the smaller camera with the flash more on axis of the lens the effect will be more pronounced since closer dust particles will be illuminated.
SOURCE:
What could have happened to my memory stick pro duo? I took pictures and was able to view them perfectly fine. When I went to deveolpe them I put the stick in the wrong slot that was too big. The sti
When you plug this memory stick into your computer and the computer cannot detect this memory stick then the memory stick is damaged and your photos cannot be retrieved.
Jan 06, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
Can a Sony DSC-W1/w12 take a larger memory stick than 256mb?
Yes. According to the manual, the DSC-W1/W12 takes memory sticks up to 1GB in size.
Dec 03, 2010 | Sony Cyber-Shot DSC-W1 Digital Camera
Screen in my sony cyber shot is not working.pls
Normal 0 Hi,
This is a very common problem with Sony Cyber-shot, as I have such one since 2007 that takes photos pretty good, but got white screen problem after using 1 year or so. I checked some website, and found the solution of knocking the front panel, or shaking. I continued to use it in this way, often shaking or knocking. Recently, it completely turned to white, no matter how much knocking/shaking/pressing. However, I eventually fixed it in the following way:
  1. Opened the camera: only three tiny screws there, and then opened the front and back panels using a flat screw driver gently (no other screws);
  2. I guess the problem is the display, since it still does photos, just not displayed. I checked that there were two metal pieces that were attacking the board. Adjusting them to have better contact did not fix the problem. Then I took off the small cable to the screen, and noticed that this is just the power supply. Finally, I noticed that there was a large cable connecting to the screen. After disconnecting this cable (which goes underneath the memory stick box) and connecting back, plus working on several more cables I could see in this way, surprisingly it got fixed! It went to the initialized settings.
I’m not sure what step exactly fixed this problem, but I can tell that this is just a bad contact somewhere, and no special part is needed.
Hope my post is useful to all!
Oct 31, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC-H7 camera, getting red eye or white eye spots
First, here is why they are red or white spots:
The red is the reflection of your flash on the retinas of your subjects. The white are generally animal eyes reflecting back.
You will notice this on flash shots only and mostly when you use the zoom. The zoom uses a "narrow" field of view so the light that reflects back is "direct", instrad of at an angle.
The fix: Change the ISO setting (it is set too high). It is probably near the maximum sensitivity (3200?)... set it to 400 or so and try that for a while. 800 is probably the best general setting, but try 400 first.
Try not to use the flash unless you really have to, but only if the subject is less than 12 feet away. If no people are in the picture, you may use the flash for subjects greater than 12 feet.
this should work for you...
Sep 11, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Can't take a picture, just records
try taking out the battery's and then put them back on also make sure it is switched over to take photos there should be a button to change it back to photos.
May 31, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
Memory stick
Have you actually loaded them to the computer then loaded them back onto the stick? Cameras cant read images very often when loaded back from the computer- because they changed image type from EXIF[camera] to JPEG normal computer image file. This should not prevent you getting the printed however.
Jul 16, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Need some help with DSC-W1
memory stick pro comes in 4gb, 2gb, 1gb, 512mb, and 256mb sizes. sizes up to 1gb (i.e. 256mb, 512mb, and 1gb) are what the book is referring to.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
DSC W1 dead pixel
If it has the remapping option, it doesn't say so in the manual. from what I understand, every camera comes already with "dead pixels" and its already remapped so that you won't easily notice it. with time, more pixels drop off and you need to remap it again. Now the thing is, the remapping just makes the dead pixel an average of its surounding pixels, and there are photo editing programs that do the same thing, have the remapping option. so basicaly what i'm saying is that if you're out of warranty dont be in a rush to get it fixed. cheers
Is full EXIF available for W1? Menu Items
You might try the free exif viewer: http://www.opanda.com/en/iexif/index.html Once installed, just Right Click on your image and select View Exif
Sony Cyber-Shot DSC-W1 Digital Camera Logo
170 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
