Question about NEC MobilePro P300 Pocket PC
My P300 won't sync when it is attached to the PC Card Expansion Jacket and inserted into the USB Cradle?
    Master:
  • 903 Answers
You can prevent this issue by making sure the P300 is turned on before putting it in the cradle. This is limitation of the current operating system.
Posted on Sep 15, 2005
I copied the Motorola MC9190 content of the Application and Platform folders to the Motorola MC9090 and now it can't move on from the system booting. I tried warm boot, cold boot, clean boot from SD card,...
If it is a Windows Mobile 5 device, reload the OS in full using SD card method. If the device is Windows CE5, you can enter IPL mode by doing a coldboot, and whilst inserting the battery back in the device, press the trigger and put it in the cradle until it enters IPL. Once there, you can either use SD card with the OS Hex files or you can use USB Download from Motorola to download the files sing a cradle from your PC. It will be recognised by the PC as this method does not use Active sync.
Jun 19, 2014 | Symbol Motorola MC9090 Mobile Computer
Axim x51v won't sync
Guys it's probably down other sync software on your system like phone sync, I had the same problem yesterday, sometime ago I had installed software for my HTC phone, check in add/remove programs & uninstall anything that sync with your computer, then reinstall activesync.
welshcob
Jan 03, 2013 | Dell Axim X51 Pocket PC
IMac deactivates USB port when I connect my Nikon P300
Try connecting the camera directly to the computer, without going through a hub. If that doesn't work, then buy a card reader.
Apr 20, 2012 | Nikon Coolpix P300 26246 4.2x Fast F/1.8...
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Garmin ique 3600 hot sync issues
I had the same problem. Obtained no help from Garmin - $200 to repair.
I purchased a $7.00 IRDA (infra red) - USB device; set my Connection to IR - PC and have been able to sync without any problems. However even withupdates I have not been able to get the cradle - PC connection to work. This is not a problem however since I now use the IR connection all the time.
You must touch the screen hot sync logo not the cradle button to start the sync process.
Feb 22, 2008 | Garmin iQue 3600 GPS Receiver
IPAQ H5555 connection problems
Hi, This could be due to a few issues, try these soloutions in order below: 1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again. 2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again. 3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case: a) unplug the USB cradle b) uninstall active sync c)Click start then click control pannel then click system. Then click on the hardware tab. Look for the device under USB, right click on the device and then select uninstall. d) restart the laptop e) Install active sync f) ONLY after active sync has installed you can now plug the cradle back into the usb socket. g) Now connect the ipaq, it should now detect it.
Aug 09, 2007 | HP iPAQ H5555 Pocket PC
Not recognize the PC Card Expansion Jacket after a soft reset
Make sure the P300 has completed the boot process before attaching the PC Card Expansion Jacket. This will ensure proper detection.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Jornada 547 rebooting W2000 E-PC
there is a patch/hotfix out from MS for this: 252795 wich cures that problem and adds the IrCOMM protocol to your Windows2000 (it was missing there before).
Sep 12, 2005 | HP Jornada 547
Error message
This original question is so old it probably won?t help the original poster but instead is meant for anyone who runs across this in the future with a similar problem. If you haven?t already done so backup your data, remove any extra cards or plug-ins and do a cold-boot. If that doesn?t work the next step is to remove Active Sync and install the latest version from Microsoft. If that doesn?t help then the next thing I would try is syncing to another PC and then another cradle if possible. If the problem persists the only thing left to try would be reflasing the ROM.
Sep 11, 2005 | HP iPAQ H5555 Pocket PC
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
NEC MobilePro P300 Pocket PC Logo
102 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
