Question about Pioneer DEH-P840MP CD Player
No power on DEH-M840MP
Years ago I pushed a button to lower the front panel and get access to the rear panel. Once the front panel lowered it just died with no power. I sat it aside and forgot about it. But would now like to fix it if possible. I wondered if it could be the flex cable that I have read about?
  • matt fourman Mar 26, 2009
    i used the cd player in my car for a long time in fact i used it in about 4 cars and it worked perfectly then one day i got into my car and opened it and it just completely lost power. i have tried re-wiring it and it never worked. i even went and bought a wire tester to make sure that i hat it hooked up properly. can anyone help me in this issue-its a very expensive cd player so i dont want to just throw it out
2 Suggested Answers
jturcotte
  • 8836 Answers
SOURCE: my deh-1300mp at volumn level 35 and higher
The of the speakers is not important, but the impedance is. Check the impedance of the speakers using an ohmmeter and compare that to the spec for the head unit. Checking your maunal, which I found here: http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/1301300MP.PDF
your speakers should have a minimum of 4 ohms impedance. For more info, please read this post:
http://www.fixya.com/support/r9389300-stereo_says_protect_or_clicks_off_when
Posted on Oct 05, 2011
How to take off control panel on kenmore 970-c85092-00 dryer. dryer runs but no heat
Hello there and thank you for choosing fixya
Here is the full repair breakdown for you
Whirlpool and Kenmore style dryers - how to take apart: disconnect power first - Many dryers that I see have the two piece front, but some are the full front with no lower access panel on the bottom front ( see paragraph below ). The lower panel can be removed by using a straight screw driver to pry it off the upper clips, place screw driver in the middle top area ( below the door opening ) and "pop" it out towards you, sometimes you may have to do this at the side top corners of the lower panel as well. Once un-cliped from the top clips, the panel will have to be lifted up off the lower clips towards you. Once the lower panel is off, you should be able to see 2 screws on the bottom corners of the door panel, loosen these 2 screws off a couple of turns but do not remove them. From here you can see the idler pulley, motor, belt break switch and part of the belt. To go further in the disassembly, lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver here to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side, remove the metal clips to allow a more loose wire harness, hold the drum up slightly in one hand and tilt the top of the front panel towards you, you can now lift it off of the screws that you loosened earlier and place it on the right side of the dryer cabinet. On the dryers with a full front, use the same directions but you can ignore the lower panel and the loosen the screws parts. The front will lift off of 2 clips about 6 inches from the bottom and again be placed on the right side of the cabinet. You should undo the belt from the idler pulley and motor pulley, now you are ready to remove the drum. Just grab hold of both ends and lift it out. This style of dryer also has a rear access panel, you can see the operating thermostats, heat element connections from this point.
May 17, 2011 | Dryers
Window on drivers side froze and fell down and won't roll back up. How to take door panel off to fix the window
  1. Disconnect the negative battery cable. Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
  2. Remove the window regulator handle, if equipped.
  3. Remove the front door warning reflector.
  4. Remove the door panel screw (1) through the hole in the door warning reflector opening.
  5. Use a flat bladed tool in order to remove the rear deck release switch bezel.
  6. Disconnect the rear deck release switch.
  7. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover.
  8. Remove the lower switch bezel trim screws.
  9. Remove the lower switch bezel
  10. Use a flat-bladed tool in order to pry the front door switch bezel upward.
  11. Disconnect:
  1. Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Installation Procedure
  1. Install the front door trim panel to the door. Ensure that the retainers are locked into place.
  2. Connect the rear deck release connector.
  3. Install the rear deck release switch bezel. Press the bezel firmly into place.
  4. Install the window regulator handle to the door.
  5. Connect:
  1. Install the front door switch bezel assembly to the front door trim panel.
  2. Install the lower switch bezel trim panel. Notice: Refer to Fastener Notice in Service Precautions.
  3. Install the lower switch bezel trim screws.
  4. Install the lower switch bezel trim screw access cover.
  5. Install the door trim panel screw (1) through the hole in the front door warning reflector.
  6. Install the front door warning reflector.
  7. Connect the negative battery cable.
Oct 15, 2010 | 2000 Oldsmobile Alero
How do you clean out the filter on a whirlpool duet sport washer?
Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws and pull down the lower front access panel to remove it from the cabinet.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the three mounting screws.
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My RCA projection model P46726BA made a popping
Check the horizontal output transister. It's known to go bad.
Dec 16, 2009 | RCA Televison & Video
I am getting no response when i push the power button. I have a mitsubishi medallion 65'' 1080p tv. This just happened out of nowhere. there is no blinking light nothing. i noticed that there is power...
Front buttons . Remove the lower front speaker covers/panels by pulling . Then unplug connector ZF to the keypad . Then wait 3 minutes and try to turn it on with the remote . You may have to remove the access panel to find connector ZF (just follow the wiresdown from the front keypad). Don't touch , turn or break anything else while inside the access panel!
Let me know if that works
Oct 21, 2009 | Televison & Video
KA dryer has been running without a lint filter. Other owner. I need to know how to take off the front and back panal to clean inside due to fire hazzard. Mdl # KGYE800TWHO . Need schematic drawing. I am...
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Next, place a putty knife in the space between the upper and lower panel at the front of the dryer about 4 inches in from either side to push up the retaining clips while pulling on the lower panel. This will release the lower panel and give you full access to all the main components and most internal areas needing cleaning.
The only area affected by running with no lint filter is accessed by removing the rear panel. With rear off, the filter housing on the left will have several 5/16" hex head screws to be removed for access to the blower wheel and housing interior. With screws removed go to front and insert putty knife in the seam between the top and front panels about 4 inches in from both sides. Lift top at same time and raise when disengaged.The filter housing can now be moved sufficiently to vacuum the interior from the rear removing any large foreign objects first.
You have now cleaned all the dryer areas that need cleaning. Don't forget the airflow through the vent line of the house.
Reverse the above process to reassemble unit. Good Luck.
Wiring Diagram for your model is located at link below:
KGYE800TWH0 Wiring Diagram
Oct 02, 2009 | KitchenAid Dryers
Push Button to start and nothing happens.
Hi, The first thing you want to check is that the dryer has power to it. Then check the non resetable fuse. On most models the fuse is located in back of the dryer behind the rear panel.
Once you remove the rear panel, you will see the fuse located on the blower housing (White in color). Take continuity on the fuse. If the fuse has continuity, it is ok. If you an not access the fuse from the back, remove the front lower panel and the fuse is again located on the blower housing.
Other possibilities are door switch, timier, & motor. The fuse is most common problem!!
If I can help further, please let me know.
Thanks
Vic
May 12, 2009 | Kenmore 63942 Dryer
Lamp replacemrnt
No the lower panel in the front just pops off and the lamp compartment door is behind the lower panel
Aug 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Fuel filter
under passenger side nr back wheel,
Jun 24, 2008 | 2001 Hyundai Accent
What's wrong with TV?
how many times does it flash?
i suspect a bad red tube
sony has a recall on the tubes
http://esupport.sony.com/perl/news-item.pl?news_id=24
Dec 29, 2007 | Sony KP-57WV600 57" Rear Projection...
Pioneer DEH-P840MP CD Player Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
