Where to buy a lint trap for Mum's Sanyo top loading washing machine - Model ASW-40AP. Internet address or nearest store to Tin Can Bay QLD 4580. Thank you. Regards Robert Rogers Contact details = avalontwo@bigpond.com Mobile phone = 0427862079
5 Suggested Answers
vest6
  • 196 Answers
SOURCE: Lint problems in a washing machine.
Most newer machines do not use lint screens. Instead the lint is pumped out during the spin cycle. If there is a build up of lint then I would suspect a restriction in the pump or the inner drum drain holes.
Posted on Jan 02, 2008
onthejob5130
  • 640 Answers
SOURCE: cleaning the lint trap of my Affinity washing machine
no lint trap...the best you can do is give it a hot wash bleach with a cold rinse,,,onthejob
Posted on Jan 31, 2009
beltronic205
  • 1474 Answers
SOURCE: i have a sanyo ASW 40AP WASHING MACHINE now
If you are referring to the Spindle on the timer being loose ,this would suggest you may need a new timer quite an expensive repairif on the other hand its thewhole thing that is loose or the timer knob, both would be repaired quite cheaply...I wish you good luck
Posted on Oct 07, 2009
SOURCE: GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Posted on Jan 29, 2013
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Where is the lint trap and how do i clean it?
If the model number is true in the blue this a top load washer there is no lint trap lint collects on the protrusions on the outer side of the basket and is washed away during the rinse drain spin cycle
Aug 28, 2014 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
Would you have a user manaual for a Sanyo ASW-F6OAT washing machine? gusov@mcdermott.com
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
SANYO Owner ManualsTo find an Owner Manual for a SANYO product, enter the model # of the product below.
Please Note: We are in the process of upgrading the Owner Manual search to also include discontinued product documents. Please check back in a week or two if you need an Owner Manual for an older SANYO Product.
Model # ASW-F6OAT
Search Results
Sorry, could not find any documents that match your search criteria
Feb 21, 2011 | Washing Machines
A lot of lint left on the clothers after load finished. Rinsing twice more only helped a little. My machine is about 12 years old. Don't know model but it's a top-loading with mini-basket.
Have you ever cleaned the lint trap? many people do not realize that washing machines have lint traps too. It is usually located under the fabric softener cup in the agitator -- not sure on yours without model number. It has a lot of tiny holes in it that clog fairly easily. One trick to clean it is to put it down in the drum where the wash goes and run a wash cycle, but you may have to do a bit by hand as well. Hope this helps.
Feb 15, 2011 | GE Washing Machines
Washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Mar 14, 2010 | Kenmore 22622 Top Load Washer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
I have a sanyo ASW 40AP WASHING MACHINE now nothing is wrong with it except for the timer that controls the cycle well the i want to know the name of the bolt like thing that holds and controls the timer...
Oct 07, 2009 | Washing Machines
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
