Electro Harmonix Super Space Drum Repair
The unit has no output, no sound. I would like to have access to schematics to repair this unit. It's basically an analog synthesizer and is becoming popular again. Thank you. Paul
  • 1,512 Answers
Hey mate
Here
is the circuit for the space drum. Cool old machine. check it out on YouTube
Posted on Sep 06, 2008
Name some best Distortion Pedal. Where to buy them?
The best top 5 distortion pedal are:-
  • BOSS Audio DS1 Distortion Guitar Pedal
  • Pro Co RAT2 Distortion Pedal
  • Boss BD-2 Blues Driver Guitar Effects Pedal
  • Electro-Harmonix Nano Big Guitar Distortion Effects Pedal
  • Electro-Harmonix Soul Food Distortion/Fuzz/Overdrive Pedal
I use to buy any distortion pedal from this site
Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study as they guide the best to buy the best.
Jan 02, 2017 | Music
Chorus on- no problem- noise free. Chorus off- big problem- massive hum. This item is supposedly "new" (stupid me, I bought from Ebay...)
It sounds like the bypass contacts on the pedal are not working... this may be right in the pedal switch itself. With unit in off position, use an ohmmeter to check continuity between in and out cable tips.
Sep 07, 2011 | Electro-Harmonix Electro Harmonix Neo...
A big hum of 100 c/s in the output,i need the schematic for repair
You must be on 50Hz power. You don't really need a schematic to repair the unit. Since the hum is twice power line frequency, the likely cause is the electrolytic filter cap for the high voltage has failed. The cap should be obvious in the unit. It will be near rectifier diodes and have a voltage rating above 50 volts. To test, bridge the one in there with another cap observing the correct polarity. If hum changes, replace the original cap.
May 25, 2011 | Electro-Harmonix 12ay7 Tube Microphone...
Dear Anyone @ FIXYA , I need to get a slightly poorly Electro-harmonix super space drum back to match fitness . Currently its output is generally noisier than it...
You may or may not get some info from this link:http://www.ehx.com/forums/viewthread/1368/#13053 This thread about the factory is old but may help:http://www.ehx.com/forums/....it/viewthread/1301/P0/ Just some suggestions.
Oct 13, 2010 | Music
I purchased a sony betacam SP unit from a guy (model #2650) - its in nice shape and told it was tested and works. When i put in a small or large tape - all i get out of it sound and "bluescreen" - i have...
The "super" output should give you playback video just like the other outputs, only with the on-screen display. These decks use separate video and audio heads; dirty video heads could produce a "no video" symptom.
Mar 15, 2010 | Sony BCT-60MLA Digital Betacam SP Tape
It stopped working and smelled burnt
I suspect the inut power circuits have a failure. Electrolytic filter cap and the votage regulator (probably a 7805 type) may have failed. IF the 7805 failed, then there is likely a short on the 5 volt supply to the electronics. In short, unless you are adept at electronics, you need to take it to an electronic tech for repair.
Nov 30, 2009 | Electro-Harmonix The Wiggler
No video output from RCA connections. Audio is okay.
s- video is alright to use, its just a substitute for your rca cords
Mar 24, 2009 | Sharp DV-SR45U DVD Recorder
Fender Vibro King Pilot light out??
Hi superleaddud
MOst probable, is that an output tube went west(decrease in vol), and in turn popped the fuse(pilotlight went out). It is always a decent first bet that this is what has happened. You get generally 6 months out of a set out output tubes if you use the amp often, and at gig levels every week. I would first check and replace the fuse, and then the output tubes. GT 6L6GE are factory for that amp, and always a fair bet to use the same to replace them. If you cant extend to the budget for the GT's, then Russian made (Sovtek) Electro Harmonix make a decent quality tube that sound good in guitar amps. . Always replace them as a pair, and buy them gain matched. Get the Grove Tubes from a music store, and the Electro Harmonix from an amp repair specialist. Happy to answer any question you may have about the problem. Cheers. A FixYa rating is a great reward for my assistance to you.
regards
robotek
Nov 24, 2008 | Audio Players & Recorders
A buzzing sound
The cables always a usual suspect, but if you are using a tube mic, wich have their own power supply, you don't use phantom power and it can damage the mics power supply, so take phantom power off that mic and if that doesn't cure the buzz then I would change the cable next.
Jul 18, 2008 | Electro-Harmonix EH-TM Microphone
518 people viewed this question
 Grubhead
Grubhead
