How do I remove the closed caption from T.V. screen. I tried with the cable remote and there is no cc option in the menu.
  • Anonymous Jan 04, 2009
    remove close caption from screen
    Philips
    Scholar:
  • 141 Answers
It may be labelled "subtitles"
Posted on Sep 04, 2008
How do I get the closed caption off my tv
I have found that Closed Caption in a function of your television service and not of the TV itself. We have had cable TV and used the menu function on the cable remote to find CC and select 'off'; we now have DirectTV cable TV and use the remote for the receiver to select CC and 'off' on the drop down menu of CC. We get to CC by pressing 'info' on the remote and a list of options appears at the top of the screen, one of which is "CC". Pressing the right arrow key moves the cursor and when on "CC" pressing "SELECT" creates a drop down list; "OFF" is the option to turn off Closed Captions.
Different types TV service (over the air with antenna will likely require changing the TV mode to CC off on none), but if you use cable (Time Warner, Charter, ATT Uverse, etc.) or satellite (Dish Network or DirectTV) then the tuner or receiver will likely have your CC option.
Feb 01, 2015 | Vizio Televison & Video
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
Unable to find how to access the closed captions section
Hi scorpiow2001
If you find the tools button on your remote you should find captions vision in the section of the menu hope this helps.. Cheers nikki
You can go to this link and download the manual for you tv
http://itg.beckman.illinois.edu/visualization_laboratory/equipment/multimedia/manuals/KDL40-46XBR2.pdf
Please take a few seconds of your time to rate my solution as i have taken time to answer your question the best i can Thank You......
Jan 17, 2011 | Sony BRAVIA KDL40XBR 40 in. LCD TV
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How the **** do i take off captions off my philips tv
Hello
Press CC button on the remote to display the current Closed Caption Setting.
Press the CC button Repeatedly to choose from the four Closed Caption Options [CC OFF,CC 1, CC 2, CC MUTE].
When finished press the Status/Exit button to remove the Menu from the Tv screen
From the above said four Caption options just select as your need. OK.
Nov 12, 2010 | Philips 32PT6441/37 32" TV
2008 Samsung 32" Flatscreen 720p Channels are
The cc has been enabled on your cable box. Usually there is a hidden menu accessed by turning off the cable box. Yes I did say turning off the cable box first. Then immediately pressing the menu button on the front of the cable box. The hidden menu should pop up and one of the menu options will be closed captioning,. Disable it.
Nov 09, 2010 | Samsung LN32A540 32 in. LCD HDTV
I need to activate CC for my Dad, Please help I have to go to work. I have a flat screen SOYO
Determine if closed captioning is available on the program that you've selected. In your program guide, the letters "CC" should appear at the end of the description.
Locate the closed captioning option on your remote. Some remotes have a "CC" button that you simply need to push to activate closed captioning
Locate the closed captioning option in your television's menu if there is no "CC" button on your remote. To do this, push the "menu" button on the remote control. The closed captioning option will probably be in the same section as the language function.
Set the closed captioning option to "on." Within several seconds, you should see the text appear on your screen.
To use closed captioning for DVDs, look for the "CC" label on the lower back section of the DVD case where it lists audio information. Turn on your TV's closed captioning and you should see the captioning like you do on a television program. Alternately, some DVDs include English subtitles that you can turn on in the setup/language menu of the DVD.
Thank you.
Aug 28, 2009 | Televison & Video
New Toshiba 37" flat screen always displays Closed Captions. Feature is turned off with TV remote, feature not available on Cable remote. Toshiba says it is Cable company problem, Mediacom cable can...
I've had this problem for a bit, it seems that there are two ways to turn off the closed captions.
1:Menu--->Preferences--->CC and Digital Audio Selectors. This displays the menu on the bottom of the screen with the choices of Closed Caption formats and digital audio. This is not the correct menu to be in. This turns off the CC as long as the TV is not turned off or the input is not changed. This is a temporarily either turns the CC on or off.
The Solution:
2:Menu--->Setup--->TV Settings--->Closed Captions Settings Displays a menu in the center of the screen, with the options of Turning the Closed Captions on and off, the Analog CC Mode and Digital CC settings. You must turn the Closed Captions off in this menu or the changes to CC are temporary.
For the record:
1. I'm aware I'm 2 years late on this, but I just want others to be able to solve this issue on their Toshiba. Don't worry, my Toshiba is the same age as yours
2. I've lost faith in Tech Support ages ago. I'm sorry that they were that incompetent.
3. Its ridiculous that there are two entirely different menus to alter the closed captions. Took me forever to figure this out.
Hope this helps you and others.
Jun 17, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
