Question about HP DeskJet 5740 InkJet Photo Printer
Every third or fourth line does not print
When I print a document, the ink is fine, but it leaves out one line every three to four swipes across the page so the lettering is shaved off on top of that line.
Same problem for me-another site said clean contacts on print cartridge with a lint free cloth and another having the same problem had success
Posted on Oct 15, 2009
  • 724 Answers
Test it by changing your font color and prove it either way that is all I can say yiou do not check it this way I have no other ideas
Posted on Jul 31, 2009
I have a brother laser printer that prints one page fine, but subsequent pages fade to nothing. any solutions?
That sounds like maybe a printer cartridge problem. Perhaps the ink flow is not working properly.
Feb 21, 2018 | Brother Office Equipment & Supplies
Tip
Mr. Worldvet - Your Tip "Ink Absorber Pads - Cleaning them How To", for an HP...
Things you will need.
Needle nose pliers.
Paper towels
97% rubbing alcohol
Plastic gloves.
Flashlight
Disposable waste container, lined with plastic.
Disposable plastic tray about 6x9 or thereabouts.
Plenty of ventilation, outside if need be.
a. With the printer on, open this lid as if to change cartridges.
b. Turn Printer off. Unplug the printer. Unattach the communication cable. You will be moving it to a work area with excellent ventilation, such as outside.
c. At the far right where the the cartridges normally park themselves when not printing you will see a platform with rectangular compartments. When the cartridges park, this platform rises, seals off the nozzle area and captures any leaking ink, which till happens today.
d. Examine the platform with your flashlight and you will see what looks like sponges in the compartments. This material with holes in it, like a sponge, is plastic.Put on your gloves.
e. Place a paper towel folded over on itself underneath this platform as best you can to catch any spilling ink.
f. Use paper towels soaked in alcohol slightly and your needle nose pliers to push
the paper towel into each compartment, gently at first, until the majority of ink is
removed.
g. This will take quite a long time and plenty of paper towels and patience. So be
patient and ready for the long haul. Avoid smoking and the fumes.
h. At some point the sponge material, itself, may become dislodged and loose.
When you witness this, go ahead and remove it carefully using your needle nose
pliers and place it on some paper towels placed inside your disposable plastic tray.
i When you have one or both, if needed or more sponges removed and in the tray,
pour alcohol over these until the ink runs pretty thin. Leave to everything to dry.
i. Use a paper towel damp with alcohol and your pliers to clean out the compartment and its sides as best you can.
j. When you have completed these tasks allow the compartments and sponges to dry.
k. You are ready to reassemble the sponges into the compartments. Do so now.
l. Nearly done; take a towel wet with alcohol and hold it very gently against the bottom of the ink cartridge until ink flows freely onto the paper towel. If its stubborn, knock
the cartridge gently but sharply against a hard surface with the alcohol soaked towel held against the nozzle area.
k. Re insert the cartridges now.
l. Return the printer to its working location, attach power, attache the comm cable and with the lid closed apply power.
m. Run your printer through its normal setup routine, deep clean the print heads, run a nozzle check and finally do a print head alignment.
m. Your Printer is now ready to be used again.
Thank you,
Worldvet
on Feb 16, 2009 | HP Officejet 5610 All-In-One InkJet...
How can I get my printer to print in color rather than brown? more info
Hi Harold
I have a feeling that this is a problem that you will only be able to resolve by changing the colour cartridge for a new one and then doing multiple head cleaning operations.
It sounds as if the three tanks in the colour cartridge have become severely contaminated with ink from the others, thus giving this overall brown colour on the page, whichever colour the computer tells the printer to print.
To check this you may be able to use something like a Word document and using the font properties, change the colour of the font on the screen for a number of different lines (eg one line - bright yellow, another - bright red, a third - bright blue, a fourth - black) print this out and see what colours you get.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 21, 2014 | Canon MP280 All-In-One InkJet Printer
Label is printed fine but each printed label print blank line before label print
To isolate problem run a test label from printer.Does the same thing happen? If so it is a printer problem.If not the problem is in the document itself.
Apr 24, 2014 | Zebra LP 2844 Thermal Printer
Almost every 4 lines the ink is very faint
The print-head is like a paint-brush -- it paints many "rows" in one swipe across the page.
So, some of the ink-jets in the print-head are clogged.
Run a few print-head-cleaning cycles to try to unclog all the ink-jets.
Jul 19, 2011 | Canon PIXMA MP190 All-In-One InkJet...
My fourth line on the cleaning test has a gap all across the four
Thanks anyways but i will go out and buy a new printer probably the same brand because this one worked really well .Its not with the scanner that i have a problem but the printer .Its a 3 in one that i bought 4 years ago .So thank you again .
claudettebro
Aug 16, 2009 | Visioneer 4800 Flatbed Scanner
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Hard to get out of third gear and have lost fourth
your three-four synchro or you need a new clutch, hope it's the clutch, the synchro will cost alot
Dec 25, 2008 | 1993 Mitsubishi Mighty Max
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Prints four blank pages between each printed document...
this is your data cable problem change datacable
and change setting to your computer cmos setup
go cmos setup find parralal port mode option select EPP+ECP
First you change your datacable if problem can't solve so change
cmos setup option
Aug 15, 2007 | Printronix Line Matrix P5210 Printer
HP DeskJet 5740 InkJet Photo Printer Logo
138 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
