Question about NorStar Compact Ics WithClid Trunk Mod (ntbu0686)
Unit will not access call pilot
I have link lites for both ports and a system link lite on the call pilot. I can access programming with my laptop and the system answers with auto attendant, but when you try to access voice mail with any phone on the system it says inactive feature and you cannot access voice mail with any of the feature codes including admin.
  • 105 Answers
Start with "Feature 9 (star) 1" from a Norstar telephone, to view the CallPilot Feature Code list. Then enter the System Administration feature code.
Good Luck.
Posted on Aug 11, 2010
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
I have a desa gas log heater when the heater lites and goes out the pilot lite goes out also
I would start with cleaning the Pilot ODS Assembly and also reseating the thermocouple.
Here is a link to cleaning instructions.
Oct 08, 2012 | Desa International Unvented Gas Space...
How do I lite the oven pilot.
Sorry to read about your problem, I hope this helps you out.
most new oven's, gas or electric you do not may have a defective unit....
if its real old, you oven knob should say pilot...if not you have a newer oven...
then you have a defective pilot system
Dec 25, 2010 | Ovens
The oilot lite keep going out
Check to see if the pilot lite is going past the pin- (flame sensor) if not then your flame is too low , Clean the pilot oriffice or use air and blow out the system for dust.
Dec 08, 2009 | Desa International Heating & Cooling
Pilot is lit, but burner will not come on. I jumped TH/PP to TH then burner comes on. Pilot generator = 350mV.
More than likely the tempature control is defective, since you effectively bypassed that connection. I found a manual for your unit which shows different types of ignition. I'm not even sure if the millivolt system is covered in this manual. Here's the sight
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Oct 23, 2008 | Acer Aspire 5670 Notebook
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
NorStar Compact Ics WithClid Trunk Mod (ntbu0686) Logo
230 people viewed this question
Top NorStar Computers & Internet Experts
Computer Links
Alun Cox
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
