Samsung Air Condition won't turn off
I can't turn off the air conditioner. The remote appears to work but not communicate with the air conditioner. The manual on / off switch has no effect. The only way to turn on and off is with the circuit breaker. When on, it appears to be stuck in turbo mode.
  • tortugaabajo Sep 04, 2008
    I have a Samsung air conditioner. I had put in new batteries and the remote seems to be fine except that nothing happens with the air conditioner. The manual on/off switch on the air condition does not work. I have only been able to turn off the air condition by flipping the circuit breaker. When the circuit breaker is on then the air conditioner lights show it is on in turbo mode (red light on) but doesn't actually work. We may have to try to find a repair man. I appreciate that you took the time to send a suggestion. Thank you.
  • Anonymous Mar 22, 2014
    My landlord wants me to test the air conditioner this winter for the summer. Will cold weather effect the conditioner's performance?
CHECK the remote batteries?
Posted on Sep 04, 2008
My samsung inverter condition does not switch off error C1
Try:
Switch the unit off with the remote (power button) - "C1" appears on unit
Push "Auto Clean" button on remote
Unit should switch off
Nov 16, 2012 | Heating & Cooling
Samsung Air Conditioner AS12AA9B)MC
interference of the cell and put it in the camera after the interference control and hit the button while you will see from your cell phone if a light turns on whenever you press the buttons on the control then it is ok and the problem is the indoor unit.
Apr 12, 2012 | Heating & Cooling
When ever I turn the air condition on. this symbol (HL) appear on the small screen, and it won't open What does that mean? Thank u
I think what you are seeing is "FL", rather than HL. FL indicates that the water collection bucket is FULL & needs to be drained. Sometimes. the LED letters on the screen can be hard ti read.
Hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | DeLonghi Pinguino PAC T100eco Portable Air...
Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Nov 03, 2009 | Fujitsu 24C1 Air Conditioner
The remote will turn on and work, but will not communicate with the air conditioner. We have to turn the air conditioner on manually to get it to work
Depending on the age of the unit. REmotes do go bad. Make sure you have it set on remote at the unit. I just installed one and had bad remote fron factory. Rusty
Jun 04, 2009 | AmcorAire UCHW-H12AF2 Split System Air...
Air conditioning unit is not responding to the remote
If you can't change the settings manually, then the control pad is bad. If you can and the remote won't change the temp or mode then the remote is bad and will need to be replaced.
Apr 10, 2009 | Heating & Cooling
We have a fujitsu reverse cycle air conditioner. Last night when we went to turn it off with the remote it did not respond. We needed to turn it off at the switch outside the house. We replaced the...
Check if the remote control if still good, using the camera of your cellphone point remote control to the cellphone camera and press the "on" button of your remote and you can see the light emitting from your remote control transmitter. If the lights emits that means your remote control is good, if not means the remote control is defective.If the remote control still good try to press the RST or RESET button on your remote control and try. If wont works it means that the reciever board in the indoor unit is defective.
Aug 20, 2008 | Fujitsu Heating & Cooling
Air condition won't work
THE CLICKING SOUND IS A RELAY PULLING IN ITS LIKE A SWITCH CONNECTING TWO WIRES. THIS IS A GOOD SOUND BUT IS USALLY FOLLOWED BY SOMETHING COMING ON FAN ETC... CHECK TO SEE IF YOUR UNIT HAS AN LED LIGHT ON IT AND HOW MANY TIMES IF ANY DOES IT BLINK?
Jun 08, 2007 | GE AGM24DJ Electronic Room Air Conditioner
Heating & Cooling Logo
928 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
