Question about Ulead Videostudio 8 for PC
Easycap Tried to copy a video tape to my PC via the easycap capture device. No picture, no sound. After a lot of fiddling I managed to get audio perfectly, but try as I might, I still cannot see any pictures. When I press the CAPTURE VIDEO button I get a message which says 'No input signal or weak signal' Any ideas please thanks
  • 1 more comment
  • sandrarob1 Nov 25, 2008
    connect my sony camcorder to easycap and keep getting message no signal tried both s video lead and standard video leads still no go
  • Anonymous Feb 14, 2009
    i have the same problem
  • Anonymous May 02, 2009
    no picture, no sound.
    been there, tried that solution already.
    still no picture no sound.
I had the same problem and found that if I went into the options and chnged the format from NTSC to PAL and then back to NTSC it would bring in my camera. Thanks to snrobby for the hint on the options idea.
Posted on Jun 11, 2009
Click on capture, click on capture video, click on Options icon, click on video and audio capture settings, change input source to video composite.
it worked for me.
Posted on Mar 08, 2009
Windows7 64bit & EasyCap directions
In my experience with the Easycap software the quality of sound & vision is very poor. My recommendation is as follows:
1) Use windows movie maker instead to capture video.Use the 2M byte/sec capture rate. Make sure the box for "make video clips" is NOT selected - you probably don't want your vid chopped into little bits.
2) In my experience USB audio is rubbish on these devices, so instead connect your PC or laptop audio LINE IN to your sound source. Don't forget to set sound source in RECORDING section of Control Panel Sound devices to Line In instead of your Easycap (which the Easycap drivers would have preset it to by default).
Good Luck.
May 17, 2014 | DekCell EasyCap USB 20 Video Capture...
Easycap usb adapter - shows images from video but there is no audio sounds
i c ant get sound on my pc,driver detactive saying i neet up date multimedia audio controller,anyone can help me p,lz?
Sep 16, 2008 | Leadtek Winfast PVR 2000 (663001C) Video...
Cannot get sound or colour to work
Sound:
I had exactly the same problem and solved it by updating the drivers for the USB sound/audio device.
My XP version is in Swedish so I´m not sure what it says in English, but it should say something like the following.
Go to the "Device manager" by right clicking on "This computer" and choosing "Properties", locate the "USB sound/audio device" under the "Sound, Video and Game"-category and right click and chose "Update drivers". Then chose "Search for drivers on the internet" and chose "Recommended installation".
My new drivers are called "USB EMP Audio Device". They work perfectly. Of course you have to chose these drivers under "Options/Input source".
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound.
Video:
Click on "File", then "Preferences" then "Capture" flap, check the "Allow access to capture device´s settings" box, click "OK". Go the the "Capture" flap in the main window and chose "Capture video". Now you should see "Options", click and chose "Capture properties", then "Video capture filter", click "Properties" in the same window and the chose the correct "Videostandard", for example "NTSC" for USA and "PAL" for Europe. Try all of the alternatives until you get a picture.
Make sure you have chosen the right input source under "Options (see above/Input source". Chose Composite or S-video (you´re likely using composite). I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Now you should see something, if not, maybe something went wrong when you installed the drivers/software.
Hope this helps!
May 15, 2008 | Ulead Videostudio 8 for PC
Audio in EasyCap/VS10
I wasn´t able to update the actual EasyCap video adapter, but it doesn´t seem to matter if you´re having problems with the sound. Although I can´t use an S-videocable, only a videocable, otherwise the picture turns black and white.
Hope this helps!
Mar 07, 2008 | Ulead Videostudio 8 for PC
Ulead Videostudio 8 for PC Logo
1,184 people viewed this question
Top Ulead Computers & Internet Experts
Barbat Nae
Barbat Nae
Robin Hill
Robin Hill
Sandrine Sims
Sandrine Sims
Level 1 Expert
Are you an Ulead Computer and Internet Expert? Answer questions, earn points and help others
