Question about Dell PowerEdge 1800 Server
Available memory limited to 256
My dell poweredge 1800 server keeps prompting me that the available memory is limited to 256mb meanwhile i have two 512's installed.this problem poping up at the post screen. it also keep asking me to press f1.
what could be the problem. i need your help please
  • Anonymous Sep 11, 2008
    I have the same problem with a power edge 700 server.
  • Anonymous Oct 11, 2008
    I also have the same problem. It shows only 256M where I has I have 1GB(I believe its 2 (512 mb)) . Is there any step by step instructions to fix this.
Turn off the option n the bios where it says OS Installed make sure it says os not installed
The Bios will only use 256 ram
Posted on Sep 17, 2008
Poweredge 700 will not recognized memory
Unless only one 256-MB memory module is installed, the modules must be installed in identical pairs. If you want 512MB total, you will need to populate by using two identical 256MB modules or use the same technique for larger memory sticks. That model supports up to 4GB ram of the following type;
PC3200 ECC DDR SDRAM DIMMs
May 21, 2012 | Dell PowerEdge 700 Server
Dell Poweredge 1800 server not start, i press power button but nothing hapened
Your Model of Dell Poweredge 1800 server may not have a redundant power supply. The power supply is the most like cause of the problem. order a replacement power supply and replace the faulty unit.
Oct 17, 2011 | Dell PowerEdge 1800 Server
The problem is: system memory limited to 256Mb and
From BIOS, change
Os instalation mode to OFF
Jul 15, 2010 | Dell PowerEdge 1600SC Server
I have an issue with the Dell PowerEdge 1800 video card. It displayed all the garbages (unreadable words) on the monitor when I first booted up or in the Windows 2003 OS. I went out to buy an EVGA...
Hi ngot01
Not knowing your application or tasking for your server, i cant make a full recommendation. I'm presuming you are not wanting to use this for a gaming machine.
One very determining factor is whether you are running 32bit or 64bit version of 2003. there are some fairly decent choices for cards but some won't support both 32 and 64 bit versions. If you have a particular card in mind, i would recommend first going to the manufacturers website and checking for compatibility with server2003
The geforce 5200 and 5500 from EVGA, PNY both come in PCI version with 128MB or 256MB onboard.
They are getting harder to find but are still to be found for a reasonable price online. i run a 5500 in one of my IBM X series servers dual processor with no hitches and no stability issues.
(32bit/64bit.)
32 bit support using older Nvidia drivers from Nvidia driver archives.
64 bit drivers currently available in latest Nvidia drivers version
The Visiontek Radeon 9250 PCI (ATI chipset) also runs well in both dell and IBM servers from my experience, and comes with 128MB or 256MB onboard.
64 bit support with current ATI drivers
32 bit support from older driver packages found on net.
One of the biggest considerations is whether the card will be properly recognized at first. Video cards and other peripherals behave differently in a server than in a desktop. Just dropping any PCI video card in may cause you some grief in time spent troubleshooting.
Another very important consideration is the video memory on the card.
Your 1800 requires ECC registered memory, but the onboard video memory on the video card can cause a problem when it starts trying to share the system memory. Not always, but this can cause a number problems, most common are blue screens.
Again, without knowing which version of 2003 you are running, i cant offer much more sound advice, because that is the biggest determining factor.
hope this helps, and if i have helped you, please dont forget to rate.
Feb 20, 2010 | Dell PowerEdge 1800 Server
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
Hello, my dell poweredge 1800 does not see up than 256MB RAM, how I can fix it? I have 1GB RAM on the board...
Check the RAM frequency of the RAM which should be compatible to the main board. also chk for the other RAM frequency also
Nov 20, 2009 | Dell PowerEdge 1800 Server
There is 1 gb ram in my dell poweredge server but showing only 256mb. So how to enable the ram from bios
i think you might have not fixed the ram properly. try to refix or replace it with other and check it.
Nov 18, 2009 | Dell PowerEdge 1800 Server
Physical Memory is limited to 256 MB" in dell 2600 poweredge
In the bios there is an option to install OS, make sure this is flaged as off, when you reboot you will have access to the full amount of onboard ram.
Aug 20, 2009 | Dell PowerEdge 2600 Server
Dell PowerEdge 840
reinstall your server it will resolve your porb.
Dec 03, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 1800 Server Logo
2,194 people viewed this question
Alun Cox
