Question about Kitchen Ranges
GE Stove tope range not working
We have a GE Stovetop oven range model number JSP47. We went to use the stove top this morning and it worked fine. We went back to use the oven and it did not work. I went to try the stove top again and it did not work. I noticed the clock was out so I assumed we tripped a breaker. Checked breaker and it was fine. I turned it off for a few minutes, then turned it back on. I went back to the stove and nothing. When I turned the dial for the stove top the lights on the front panel came back on and I could reset the clock and the buttons on the panel would function, but the burner would not get hot. As soon as I turn the dial to off, the stove goes dead again.
  • steve382 Sep 04, 2008
    All functions work on the control panel when you turn one of the dials to the on position but no heat to the stove top or range. When you turn the dail back off, all functions go dead.
  • steve382 Sep 05, 2008
    We have a GE Stovetop oven range model number JSP47. We went to use the stove top this morning and it worked fine. We went back to use the oven and it did not work. I went to try the stove top again and it did not work. I noticed the clock was out so I assumed we tripped a breaker. Checked breaker and it was fine. I turned it off for a few minutes, then turned it back on. I went back to the stove and nothing. When I turned the dial for the stove top to on the lights on the front panel came back on and I could reset the clock and the buttons on the panel would function, but the top burner or stove would not get hot. As soon as I turn the dial to off, the stove goes dead again. Does this sound like the circut board has gone bad?
    Master:
  • 505 Answers
All i can say last time i work with a stove it was loose wiring . how ever could be the burner . just a suggestion
Posted on Sep 05, 2008
  • 535 Answers
Check the wiring of control pannel is not working proper
Posted on Sep 04, 2008
    Brigadier General:
  • Kitchen Ranges Master
  • 3,614 Answers
Did the timer was still functioning, and the only problem was it was not getting any heat, right>
  • micromaster
    micromaster Sep 05, 2008
    Heating
    elements eventually burn out. Sometimes, when an element burns out, you
    can see that the coil burns in two, or blisters and bubbles.
    When
    your heating element burns out, you have to replace it because they are
    not repairable. If, when the heating element burns out, the infinite
    switch that controls it also fails, you have to replace it too. Also
    see the "A burner works only intermittently" section, next.
  • 19,396 Answers
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
  • Ginko
    Ginko Sep 04, 2008
    Here you get parts for your appliance, this is the control panel. If you notice that the control timer is doing funny things, like display going off etc, it is likely the board behind panel faulty.
    If only oven is not working and panel is fine it can be a faulty oven sensor, test the oven sensors (thermistor, gas and flame sensor etc.). Once you locate the fault replace defective part or rebuild wirings.
  • Ginko
    Ginko Sep 04, 2008
    Check the oven switch with a sester, see if you find shorts or a bad connection on the wires from OVEN CONTROL (ERC3B) to the oven, check fan and ELEMENT BAKE
    Also check the SENSOR ASM
    More likely the fault is within the OVEN CONTROL ,
    Probably you will need to replace it.
    Here is explained how to remove control panel.
    Click on the links above to get diagrams and buy parts.
    Contact them at 1-888-895-1535 from 7:00 AM to 9:00 PM Eastern time if you are not sure of a part number.
    Calling the part seller by phone you can also order the repair manual.
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
Stovetop & Oven not heating but clock, lights, & vent fan are working
It sounds like you are getting only one side of the power to your stove. the lights will work but no heat. your power breaker has two sides for an electric stove. It may be one side isn't reset properly. make sure that you snap the breaker completely off and then completely back on. if that doesn't work perhaps an electrician is in order or one side of your power cord has burned off at the terminal block. I have had this happen.
Apr 28, 2013 | Kitchen Ranges
Replace fuse on ge glass stove top
Maybe the top you can open above switches.
Mar 17, 2013 | GE Kitchen Ranges
How do I plug back in the GE stove top burners after unplugging them?
The two leads from the burner fit into a socket in the stove top. It's a bit tricky to get it in just right. If the three metal "legs" on the burner fit snugly into the three slots on the stovetop you did it right.
Aug 26, 2012 | General Electric Ge Stove / Oven / Range...
GE Profile Stove, stove top works but the oven will not heat up.
You will most likely have to replace the oven igniter. If you have the model number you posted under, I believe the igniter for the broiler is the same as the oven broiler, and could be swapped out to get the oven working again. (of course, now the broiler won't work until that igniter is replaced) If you'd like the part number or any further advise, comment back with the full model number off the sticker just behind the lower drawer panel on the frame of the range. Tonight, you may have to finish the chicken on the stove top.
Mar 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
Glass top
you have more than likey damaged the stove top with brillo, and once they are damaged there is really no simple cure other than to replace. in the future use a non abrasive cleaner, and NEVER use oven cleaner on a glass top, it will wreck it as well
Jun 25, 2008 | GE Spectra JBP78 Electric Kitchen Range
Kitchen Ranges Logo
328 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
