Question about Sony Cyber-Shot DSC-W1 Digital Camera
Sony W1 Questions
Today I decided to place an order for a W1. It seems to be pretty good. Now I have a couple of questions. 1) Is there a shutter priority mode? I like to be able to manually set the shutter speed for fast action scenes, or just to shoot fast enough to avoid handshake. 2) Is there spot focusing? Or just center focusing? I really like spot focusing. 7900 doesn't have it.
    Novelist:
  • 130 Answers
It has Multi AF, Center AF or fixed focus. The V1 i had went to 800ISO, if you turn the ISO up a little more may you can set a faster shutter speed. I think the only priority settings are the "scene modes" there may be an action ssetting in the scene modes.
Posted on Apr 03, 2006
SOURCE:
How to order universal remote.for frestiz??
If you have an Android phone or tablet, download an app called "Sure Remote". After opening the app, it's a pretty simple couple questions on your good to go.
Feb 05, 2017 | Universal Televison & Video
I bought Sony TV 55" and don't know how to use the stand which came with it
It is detailed in the instructions. Sony don't want their brand new shiny television veins damaged. It is towards the back of the manual as the stand is a choice of stand or wall mount.
Pretty easy, one end of the stand fixes to the television via a socket or two screws. You fit the base to the stem.
Nov 18, 2015 | Sony Televison & Video
All my captured images are white. The LCD shows a nice image, also the video works
Most likely the shutter is jammed open - the shutter is not used for video or preview, which is why they work OK. Camera will need to be serviced, either shutter repaired, or more likely replaced. May be marginal, as the shutter is part of the lens unit complete! Look out for one with a damaged LCD on Ebay and make one good camera from the two if you are good with a screwdriver !
Jun 02, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Spark plug wire diagram 94 plymouth laser
I am not sure whether you have the 1.8L, 2.0L, or 2.0L Turbo; however I have included all below.
You Posted your Car Question under a different (non car) (Home| Lite On | Spark Plug Lite Green LED| Problem) heading.
I work on pretty much only vehicles, and found your problem today.
For the 1.8L SOHC
Firing Order:
1-3-4-2
Cylinders:
(back of engine)
4---3---2---1
(front of engine)
Distributor:
...(back)
(+)..1
2..........3
......4..(+)-screw
...(front)
For the 2.0L DOHC AND 2.0L Turbo:
Firing Order:
1-3-2-4
Cylinders:
(back of engine)
1----2-----3-----4
(front of engine)
Ignition Coil Connections:
......(back)
........3
........2
........1
........4
......(front)
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Feb 08, 2010 | Lite On Spark Plug Lite Green LED
My sony dsc-w1 got very wet, caught in a rainstorm and did not have the case. I have left it dry out for 4 days and it turns on, lcd works, can read memory stick and display old pictures on the lcd. But...
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
Jul 08, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
How to network
You need to go to the microsoft website or use windows help. If you come accross a certain problem we can help but to walk you through a whole networking process is a little much. Though it is pretty self explanitory. Set up all the computers the same Wired and wireless will be different of course but not too much jst a couple extra steps for the wireless is all. Let me know if you get any questions
Dec 29, 2008 | Dell Inspiron 1721 (dndwna2_5) AMD Turion...
Sony Cayber-shot DSC-W1 digital camera
I've seen a lot of DSC-W1 cameras where the power switch/shutter button assembly goes bad. This is most likely the case.
Aug 23, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
DSC-W1 Focus Problems
Try taking some flash pictures (in fairly good light) in Manual Mode @ 1/500sec to rule that out though. Use "Center" or "Spot" autofocus. If you don't have a tripod, then use the self timer for these tests. If camera shake can be ruled out, and the camera has focusing problems even in bright light, then that unit is trashed. Sorry to hear that the Sony service center couldn't fix it right the first time. Demand a replacement.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Blurry pictures
There is a well documented problem with the W1 (and its brother, the P100). If you are shooting in good light, you will have no problem. If you are shooting in low light or flash, you will encounter various degrees of blurred photos. Unlike most cameras, the W1 has only two f-stops (f2.8 and f5.2). So the camera must select one or the other (nothing in between). The firmware in the camera will try to select f5.2 as long as it can in low light. This results in a slow shutter speed. And with flash you usually end up with a shutter speed of 1/40th of a second. A slow shutter speed is the cause of the blurred photos. If you can hold the camera perfectly still under low light conditins (and flash) you will get good photos. If you use the cameras manual mode and manually select a faster shutter speed you will get good photos. It appears that Sony could fix the problem with a firmware change so that the camera made better use of the ISO settings along with the f-stop selections. However, they have not done so.
Sep 08, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Sony Cyber-Shot DSC-W1 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
