Paper not going through to print
I have a Canon Pixma iP6210D
When I go to print something it never pulls the paper through to print. It prints on nothing and then says there's a paper jam.
  • Anonymous Sep 05, 2008
    my paper goes through half way and then stops
  • 33 Answers
SOURCE: brother hl 1440 paper jam
clean the paper feed tires with some alcahol. they are located in the upper part of the machine when you pull out the paper tray. they are gray in color. if that does not work the feed tires may need replaced.
Posted on Nov 02, 2007
HARDWAREGURU
  • 66 Answers
SOURCE: Canon PIXMA MP480 bought 4 months ago jams paper
paper jam problems are usually occured by dust and debris in the printer . clean up ur printer from inside . also align ur paper tray. that will fix the problem. thanks and take care of urself.
Posted on Jun 09, 2009
  • 12 Answers
SOURCE: paper jam problem in pixma mp145. E3 error.
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Posted on Jun 13, 2009
pineworks
  • 4041 Answers
SOURCE: E3 error and no paper is jammed
Hello There please try it may clean it up for you There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
  • 4 Answers
SOURCE: Printer keeps on jamming paper
Turn the darn thing over and shake it. there's probably something in there. In mine it was a miniature oyster cracker. Works great now but I was about to go insane until i shook it out.
Posted on Sep 08, 2010
Canon PIXMA MX880 will not pull paper from front tray when copying. The MX880 will pull paper from the front tray when printing from the computer and the rear tray when printing envelopes. I only have a...
The reason for that is the front is the paper output tray, the rear tray is where you load the paper. Anything you print, copy, or scanned (to print) will come out the output tray (in front) and will pull paper from the rear tray.
Nov 03, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Hi - My daughters Canon MP 210 printer stopped pulling paper into the printer. I did not observe any spinning of the paper grab wheel therefore I'm wondering if a drive belt broke or something else is not...
hello there
you need to check the gear that trigger the paper to pull from the tray, if the gear is making a sound when you print then totally you need to open the gear coz it might be disconnected.
thanks
Dec 23, 2010 | Canon PIXMA MP210 InkJet Printer
Says there is a paper jam everytime i try to print
Hello
Check within your paper feeder rollers there might be something stuck inside it like paper clips, coins or anything small and solid. If you can find way to open the printer without braking it, that would be nice.
Hope this helps.
Jan 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Hi :) I'm trying to print on my Canon PIxma- mp480 to no avail
Hello
This can be due to a feeder wrong setting on the printer or on your PC: your printer tries to take paper from the back feeder, whereas your paper is on the front feeder....
try to check these settings in your PC and on your printer, and retry to print, hoping this helps
Jul 29, 2009 | Canon Pixma MP480 All-In-One InkJet...
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Paper Jam!
Hello sir; There got to have something on thr paper path check very carefully, especial at the point of the paper skew.
May 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mp110 saying ''please load paper and press ok''
there is problem in the paper feeder gears of the printer.they r pulling the paper and then not able to forward the paper as they worn out or slightly cracked.so they needs replacement with deep servicing/cleaning from proper technician .it will be ok after that.
Nov 16, 2008 | Canon PIXMA MP130 All-In-One InkJet...
The paper starts to pull crooked, but then does not go in.
I had the same problem and it drove me insane!! Have you tried going into printer properties and then maintenance - there is a clean paper roller option. It has helped slightly!
Apr 28, 2008 | Canon Pixma iP6210D InkJet Photo Printer
Paper feed and printing problem
Don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others, it seems to reset the sensors or something.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through!! and hey presto it worked for me, everything printing fine now.
hope it works, let me know, Garty
Apr 08, 2008 | Canon PIXMA MP160 All-In-One InkJet...
183 people viewed this question
jasbo
jasbo
