Question about Andis Edjer 15515 Beard Trimmer
Nylon roller ball is off Center
When I put blades on nylon ball and tighten they are not in the middle. is there a way to Adjust the position of the nylon ball?
  • 62 Answers
Your trimmer will need to be sent in for service to correct this problem. If you would like to speak with a customer service rep before sending the unit in you may call 1-800-558-9441. To send the unit in we recommend either UPS or Fedex Ground as you will then have a tracking number to follow the shipping process of the trimmer. Our address is Andis Co 1800 Renaissance Blvd Sturtevant WI 53177 Attn: Repair. Be sure to include your name and address inside the box with an explanation of the problem.
Thank you for choosing Andis.
Posted on Nov 17, 2008
The blade does not tighten on the spindle and just spins freely. Even tightened down the center nut does not make a good connection to the blade.
There is a positioning "washer" that needs to be in place. If you don't line up the blade and position the washer it will not tighten. The blade will just spin around. Some even have a washer in front and in back. Be sure you have correct diameter of arbor that matches your blade too.
Feb 15, 2016 | Saws
Tip
How to Clean Your Mouse
<p><b><span>Roller Ball Type:-</span></b><br /> <p><span>For cleaning your mouse you have to do the following work.</span><br /> <p><span>1. Disconnect the mouse from your computer CPU.<br /> 2. Turn the mouse upside down and twist the roller ball retaining ring in a counter-clockwise direction to remove the ring.<br /> 3. Remove the roller ball from the mouse cavity.<br /> 4. Wash the roller ball with warm soapy water and put it in dry place.<br /> 5. Replace the dry roller ball back into the mouse cavity.<br /> 6. Replace the roller ball retaining ring and twist it clockwise to tighten.</span><br /> <p><b><span> </span></b><br /> <p><b><span>For Laser type Mouse:-</span></b><br /> <p><span>A laser type mouse requires very little care. Internally, there isn't anything required of you. If it should get a little dirty on the outside, just dampen a soft cloth with water and wipe it until it is clean.</span><br />
on Dec 24, 2010 | Computers & Internet
How do you replace he belt on a 7447 Sander
To change belt:
1) Put front roller on floor and push down until roller locks back.
2) Put on new sand paper.
3) Loosen tracking screw until front roller is released.
4) With sander running, use tracking screw to center belt.
Oct 10, 2010 | Black & Decker BR300 3''x18'' Belt Sander
When I power up my treadmil the belt does not move. If I step on the side the belt would then start to move until I move my foot.
In order of most likely cause. 1) Worn motor belt needs to be changed. Rear roller bolts need to be tightened as the walking belt has too much slack(2-3 inches lift on the edge of the belt in the middle on each side) 3) the nylon pulley on the front roller is slipping and a new roller is needed.
Oct 03, 2010 | Reebok 8050 ES Treadmill
Blade wont tighten
Here are some directions on installing the blade to ensure the proper procedure has been followed when installing.
  1. Set the blade orbit selector lever to position III.
  2. Fit the supplied screwdriver into the top plunger hole and loosen the internal blade securing screw about 3 to 4 turns counterclockwise.
  3. Insert the blade into blade plunger at a 90° angle to the cutting direction. With a slight upward pressure, turn the blade teeth forward (direction of cut) and guide the back of the blade into the groove in the center of blade roller guide.
  4. Pull gently down on the blade to seat the blade tabs in the plunger.
  5. With the blade in the proper position, securely tighten the blade screw by turning the screwdriver clockwise.
I hope this helps. Please rate on how helpful the answer was. Good Luck and have a great weekend.
Apr 03, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do i adjust my new outliner 2 blades?
remove the 2 front screws that hold the blade, remove the blade, this has two small screws losen the screws DONOT NOT remove these screws now mve the smaller blade up or down to the hieght you want. when u finish with your adjustment tighten the small screws replace the blade and center the blade in middle.
Sep 27, 2009 | Andis Outliner II Hair Trimmer
Riding mower
If the grass is very tall (more than 10") you will have to slow down to less than 1 mph, if you have a mulch kit on this unit, remove it to get the grass out as quickly as possible. Also, sharp blades & a level deck are important.
Sep 23, 2009 | Garden
Worn seat wheels on Tunturi 202 need replacing
Good News! Home Depot sells (on-line only) drawer rollers that work PERFECTLY for the Tunturi Rower machine seat rollers. The only difference is the wheels are nylon instead of rubber. Model Number R7228, Internet Number: 100142874. Item description: ROLLER, W/ 1/4" -20 STUD, 1-1/8" NYLON, BALL BEARING. There are two rollers in a package, $5 for two! http://www.homedepot.com/buy/prime-line-1-1-8-in-nylon-ball-bearing-drawer-rollers-2-pack--r-7228.html
Jul 01, 2009 | Tunturi Exercise & Fitness
Replacing ball joints on 1994 2500 silverado pick up plus replacing pittman rod
You will have to get a couple of tools for this job, a "pickle fork" and a pitman arm puller. You may be able to rent or borrow, but you should be able to buy them for about $80. They come in handy. To do the ball joints, jack up the truck and block it. With the wheel off remove the big nut on the inside of the spindle. Wedge your pickle fork between the spindle and control and give it a few belts with a hammer until the ball joint comes outof the spindle. Don't be shy with the hammer. Next you remove the ball joint from the control arm. IT may be riveted or bolted. Grind the rivets off, with a mini grinder. Bolt the new ball joint into the control arm tight and put it back in the spindle. Tighten up the big nut. If you are using a socket or box end wrench when you can't turn it any more it should be tight enough,put your shoulder into it when you tighten. Do your ball joints one at a time. You can use this procedure to remove the pitman arm from the center link. To remove the pitman arm from the steering box, remove the nut first. Hook up your puller making sure it is centered on the steering box shaft and straight with the angle of the box. Tighten the center bolt. When it gets hard to turn with your wrist give the bolt a sharp rap with a hammer. REpeat this until the pitman arm comes off. Put the new one on,they are usually made so that they will only go on in one position on the steering box. Make sure you before you tighten it that you didn't put it on upside down. When you sure it's on right tighten it up. Itshould return to a similar position on the steering shaft as the old one you took off. Reconnect the other end to the center link. Make sure you grease whatever you replace, and get your truck aligned as soon as possible, or your tires will start to wear funny.
Jun 12, 2009 | 1994 Chevrolet Silverado 2500
R205 Tunturi Rowing Machine, needs new bearing wheels under seat
Mar 31, 2009 | Exercise & Fitness
Andis Edjer 15515 Beard Trimmer Logo
139 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
