Question about NEC MobilePro P300 Pocket PC
Failed to recharge the main battery before it is completely drained
How can I avoid having to completely re-set up my MobilePro P300 when I have failed to recharge the main battery before it is completely drained?
    Master:
  • 903 Answers
You can avoid having to completely re-set your personal settings by using the back-up utility pre-installed on your MobilePro P300. To do so, tap Start --> Programs --> My Settings and tap Backup Utility and follow directions to back-up personal settings onto a SD or CF card. You may also use your desktop Microsoft ActiveSync software to save your MobilePro P300 personal settings onto your PC. To do this you open the ActiveSync window on your desktop and go to Tools --> Backup/Restore and follow instructions.
Posted on Sep 15, 2005
Not recognize the PC Card Expansion Jacket after a soft reset
Make sure the P300 has completed the boot process before attaching the PC Card Expansion Jacket. This will ensure proper detection.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Synch or move files
The Pocket PC 2002 software allows you to transfer files over to the MobilePro P300. Please look under "Synchronization" in the Getting Started Guide for details on your particular situation.
Exhaust my main battery
It is estimated that you will have a few days to recharge your battery if the battery is exhausted.
Sync via IR
There are a number of things to check: * You should first make sure that the PC that you are synchronizing with has an IR port. * If you have Palm software loaded, you should disable it. * If your PC has an IR port, then you should verify that the Microsoft ActiveSync software settings are correct. To do this you open the Microsoft ActiveSync window on your desktop and go to File --> Connection Settings and verify that the box that allows infrared connection is checked and the IRDA is selected. * Change the angle of the unit and make sure that there is nothing interfering with your signal. * Try removing the LCD protection cover.
How many recharges can it take?
The MobilePro P300 can be recharged hundreds of times, which is estimated to be equivalent to nearly 3 years of consistent use.
Remove the LCD protection cover
There are two round pins on the top of the MobilePro P300 protection cover. You must pinch the two pins together in order to release the hinge and remove or replace the cover from the unit.
Methods of extending the battery time
Decrease the Front Light brightness while the MobilePro P300 is on battery power. To do so, tap Start --> Programs --> My Settings and tap the Front Light icon. Click the "DC" tab and decrease the brightness level to the desired level.
Disable the record button
Tap Start --> Programs --> My Settings, tap Wakeup Icon, remove the check mark from "Recorder Button", and tap "OK". The record button will not work when the MobilePro P300 is off.
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
NEC MobilePro P300 Pocket PC Logo
108 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
