Question about HP LaserJet 1020 Printer
Printer Problem I HAVE A LASER PRINTER N I HAVE SHARED IT IN WORKGROUP, WHEN I TURNOFF MY SYSTEM IN EVENING AND RESTARTS NEXT MORNING PRINTER IN OTHER SYSTEMS DOES NOT PRINT N SHOWS OPENING, AFTER SOME TIME ACCESS DENIED
  • 54 Answers
Brother Switch of the firewall and disable the anti virus in the system which the printer is connected and then try again to open
hope this may solve
Posted on Sep 23, 2008
Not Sharing pc for win 7
It may be because of the workgroup setting. WINXP uses a default workgroup value of MSHOME. WIN7 uses a default of WORKGROUP. What happens then is that all computers can connect to the network and access the internet, but shared files and folders will not be seen due to the two different workgroups,
To change the workgroup in WIN 7:
Click START.
Right click on COMPUTER, choose PROPERTIES.
In the SYSTEM window, choose ADVANCED SYSTEM SETTINGS
in the SYSTEM PROPERTIES window choose the COMPUTER NAME tab.
Observe "Workgroup" name.
To change, click the CHANGE button
Put the new workgroup name in the WORKGROUP block
(WINXP default is MSHOME)
Click OK
Close all windows
You will need to restart PC to set the new workgroup
Nov 11, 2013 | Computers & Internet
Network a Konica Minolta printer
FILE SHARING BETWEEN COMPUTERS ON A NETWORKBasicallyif you have a wireless router with several laptops and desktop PCs, which canaccess the Internet at the same time, then you have working network withthe laptop and PC.First makesure the laptop and PC have the same Workgroup name(it may already have Workgroup as the Workgroup name, you can change it if you wish). To changethe Workgroup name open Control Panel - System -click on Computer Name tab - click Change and you can change the Computername then select Workgroup and enter orchange the Workgroup name - click OK and OKagain.Nextenable Sharing on both the PC and laptop open My Computer - right click onthe C Drive - click on Sharing tab - tick Sharing this folder on thenetwork - add a Share name to identify the computer/folder (eg Cdrive on PC).If you donot enable sharing on the drives or folders then they will not be available tothe computers on the network.If you havemore drives, then repeat this for the other hard drive and or CD or DVDdrives.Re-boot thecomputers and you will be able to see the computers on your network through MyNetwork Places.SETTING UP A SHARED NETWORK PRINTER
Any printer that isconnected to a computer and is connected on a LAN can be configured so allother computers on the same network can print to this printer. This means thecomputer with the printer attached to it MUST be booted up at all times whenother computers want to access the printer.You need to install theprinter driver on the computer and configure it as a Shared printer.The other computers on thenetwork need to add this printer to their computer.Follow these steps toset-up a shared network printer :-1. Connect the printer tothe computer and install the printer driver.2. Open Printers and Faxes- right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change theShare name, then click OK3. Right click on theprinter - click Properties - click Print Test Page to confirm printerinstallation.Follow these steps toconfigure the computers on your network :-1. Open Printers and Faxes- click Add a printer - Next - select a network printer, or a printer attached to another computer - Next.2. Select Browser for aprinter - Next3. Click on and expand theMicrosoft Windows Network down to the computer with the printer - Next4. Select Yes for - Usethis printer as the default printer - Next - Finish5.Right click on the printer - click Properties - click Print Test Page toconfirm printer installation.
Jul 27, 2012 | Konica Minolta Office Equipment & Supplies
Make 2 pc's see each other
This is a common issue with XP and later versions of windows. Check that both computers are in the same workgroup.
On XP right-click My Computer, select properties, go to the Computer Name tab and check the workgroup name.
On Win7 right-click My Computer, select Properties, click Advanced System Settings, go to the Computer Name tab and check the workgroup name.
If the workgroup name is the same on both machines but neither come up in My Network Places then try changing the workgroup name to something else on both machines and restarting them, this usually clears up that issue.
If they still don't show up check that you have Network Location Awareness and File And Printer Sharing turned on on both machines.
On Win7 this is checked under Network and Sharing Center, Change Advanced Sharing Options. Make sure that Turn On Network Discovery and Turn On File And Printer Sharing is marked for the current profile (Home or Work, normally).
On XP go to Network Connections, right-click the connection for your LAN and select Properties, make sure that File And Printer Sharing For Microsoft Networks is checked. Then, go to Administrative Tools, Services and make sure that the Network Location Awareness service is running.
Both machines may need to be restarted after this, but that should fix the issue. If not, please let me know.
Jun 09, 2012 | Computers & Internet
How to I set up my dell laptop in my house to print wirelessly from a canon mp780 printer?
Mar 25, 2012 | Canon PIXMA MP780 All-In-One InkJet...
One of my pC is a part of nework and not allowing to access from anothe netwok pc , showing error message, Where as from this PC i can access another PC with network Tried no. of solution , but no one is...
First of all, you check the workgroup of your PCs. if the system is seeing other PC on the network. then you follow this steps. To know the workgroup of your systems. right click on the My Computer and point to Properties, Click on Computer Name, There you see options
1: Computer Description: You can type the name of your company like John Cybercafe
2: Full computer name: the name of the PC like System01 or Machine01 etc...
3: WorkGroup: is a collection of computers on a local area network (LAN) that share common resources and responsibilities. If you use the default setting which is "WORKGROUP" workgroup normally be on capital letter.Any name you use as your workgroup, make sure you use it on all other PCs to avoid conflict. Now click on Network ID, Next-you see two options, select the first options and click Next, you see two options again, select the second option which is "My company uses a network without a domain" click Next again, you see "WORKGROUP" leave it as it was and click Next, click Finish. A window will pop out telling you to restart your computer. Do you want to restart? Yes and Cancel, click Yes to restart the system. After restarting your system. Connect your network cable to the system or if is already connected. Go to Control Panel, click on Network Setup Wizard on Network and Internet Connections. Click Next---Next--There you see two options. select the first option and click Next, you will see another options
Computer Description:your company name would appear there like "John Cybercafe" in capital letter
Computer name: System01 or Machine01 in capital letter etc.........click Next to proceed. Another option is WORKGROUP. Don't change it to anything, make sure the name you used for your workgroup is the same thing with other computers.click Next again. This is where you have problem.
1: Turn on file and printer sharing: your computer will see other computer on the network and can share file and printer to each other.
2: Turn off file and printer sharing: your computer cannot share file and printer to each other, they can see each other on the network, but they cannot access each other. select the first option and click Next--Next, wait a moment for the system to share file and printer.after that,you will see four options, select the last option which is "Just finish the wizard, I don't want to run the wizard on other computers and click next and finally Finish.Now go to view my workgroup computer and access the computer again. Thanks and Good luck......
Jan 19, 2011 | Computers & Internet
Just bought win 7 laptops wont connect to my lexmark x1180 printer connected to my desktop running xp any ideas?
Enable File and Print Sharing on your XP system.
Click Start
Click Control Panel
Click Printers
Enable "sharing' for the printer.
Click Start
Right-mouse click My Computer
Click Properties
Click Computer Name
to show the current "workgroup" name on your XP system.
On the Windows 7 system:
Configure it into the same workgroup.
Then, "Add Network Printer", connecting to your XP system, and pointing at the shared printer.
Dec 10, 2009 | Lexmark X1150 All-In-One InkJet Printer
Cannot reboot
Just run a system restore to a pervious date
go to start -> accessories--> system tools--> select system restore
select a back date and hit next and follow the onscreen instructions this will solve the issue.
May 04, 2009 | Acer Aspire 6920 Notebook PC
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
HP LaserJet 1020 Printer Problem
Unfortunately this is not a printer problem, it's an application problem.
Are you on a network? what App. are you using?
Sep 18, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
117 people viewed this question
Seeker5211
Seeker5211
