Question about Xerox Office Equipment & Supplies
I have a Xerox WorkCentre Pro 412 and I'm tring to hook my computer and it together and it reply back that its not digital and a freind told me i had to down load something toget it to work can you help me please
    President:
  • 2,072 Answers
You can only print to a 412 with a parallel cable. You can not use the USB port, That is for software upgrades.
You can go to Xerox.com, click on support and drivers, then in the search enter wcp412, click search then click Downloads and drivers, DOwnload both the PCL Print Driver and also its good to have control center on your computer.
The print driver is all you need to have to print ot the machine once you have the parallel port connected. When you select the driver and it starts loading you want to load it to a LPT1 port.
Posted on Sep 04, 2008
What is error 027-502?
Appears to be error message related to networking.
26171215-uilodj0wn3aoics0ffhdkown-5-0.png see page 412 of 454 in the attached manual Xerox WorkCentre 5230A System Administration Manual Page 412
Apr 21, 2016 | Xerox WorkCentre 5325 5330 5335 Black...
Is there an on/off switch for the Workcentre pro 412?
there is no on/off button for this machine however for more features try THIS link for user manual
Nov 15, 2011 | Xerox WorkCentre Pro 412 All-In-One Laser...
I look for CD Driver for Xerox WorkCentre Pro 412
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
Nov 14, 2011 | Office Equipment & Supplies
Heat error
hi
this error is due to the fuser so to take of this issue you can remove the fuser and put it back but to be on a safer side i would suggest you to contact the customer care of xerox they will guide you accordingly and in case if the printer is under warrantty and the issue is a bad fuser they will be able to replace it
regards ali
Feb 17, 2011 | Xerox WorkCentre Pro 412 All-In-One Laser...
How do I scan a photo onto my laptop using a Xerox WorkCentre Pro Scanner?
Just attach the scanner to your laptop.Install the drivers of your scanner into your laptop and restart the laptop.
Now start scaning your documents..
Regards,
polysandy
Apr 06, 2010 | Xerox WorkCentre Pro 412 All-In-One Laser...
I have a Xerox WorkCentre Pro 412 and it will not power up.
First and most simple. Plug something else into the outlet to make sure it works. If this model has a removable power cord then try re-inserting the cord. While you are there and with the cord installed, lift up then push down slightly and see if it comes on. If the power cord is removable the receptacle where it plugs in are notorious for breaking the solder connections. If this is the case it just needs to be re-soldered. If the outlet is ok, the cord is ok or hard wired in then you may have either a blown main fuse or a bad power supply.
Good Luck
Nov 30, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Xerox workcentre pro 412 printer do not work
i changed the usb cable to anthor one Parallel Port
Cable so i think the adapter of usb cable is damaged so now it work.
Jul 06, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
Describe your Xerox WorkCentre Pro 412... Problem:Scanner
Turn off the copier first.
Look under the copier, there by where the copies come out, look just above that portion of the machine. There will be a green sliding latch; one side has a picture of a pad lock for lock, the other side has a un-lock position, slide the latch to the unlock position.
Turn on the copier, and the machine should work.
That latch is for transporting the copier when being moved. It will hold the scanner in place so it does not move around.
Apr 23, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
62 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
