Question about IBM NetVista A40 PC Desktop
BIOS I've built a PC from scratch and when I turn it on it says press the "Delete" button to enter "Setup" and the "Tab" button to enter Bios message. So I've tried pressing the Delete button to enter Setup, and the following screen says "Entering Setup....." but nothing happens. I've waited and waited for hours but it does nothing. I've also tried pressing the "Tab" button and the Bios message comes up but nothing else happens. Any help would be much appreciated, thank you.
  • IBM Master
  • 3,051 Answers
Hi there:
it looks like there is somthing not hooked up or set up correctly i would first hit the esc key whren this appears and see what that does than double check the jumpers on the harddrive to ensure that it is being assigned as master and than check the cd rom if this is ok and you are positive of this unplug the all cords and cables to the harddrive first and try it ,, and if it still comes up unplug the cd rom and try it again and doble check that every thing else is properly installed from the powersupply to the motherboard and make sure that you have the harddrive properly assigned ie master/ slave ok let me know how this works for you
best regards mike
Posted on Feb 18, 2009
How to Insert Boot Media?
Mostly you wil have to adjust the BIOS of the computer to boot from USB or DVD media.
When booting most computers mention the button(s) to press to get into BIOS:
--A Function key (such as F1, F2, or F3)
--The Esc key
--The Delete key
On some PCs, entering the BIOS may require pressing another key or a combination of keys. Keep your eyes open for an on-screen message that says something like: --'Press F1 to enter setup'
--'BIOS settings: Esc'
--'Setup = Del'
--'System configuration: F2'
If you don't catch it the first time, simply try again. Your computer's documentation may also tell you which key to press.
3. When you know the right key, start the computer again and press the key when the first screen pops up: You may hear a confirmation beep or see a new message. If you timed it correctly, you'll be in the BIOS within a few seconds.
Good luck,
A.Misset
Oct 18, 2016 | Computers & Internet
Locked out from eee box 1035 need to reset bios how?
Try this. Right out of the manual. The reset button is the little pin hole next to the power. Will need a paper clip that is straightened.
Entering the BIOS Setup
BIOS (Basic Input and Output System) stores system hardware
settings that are needed for system startup in the PC.
In normal circumstances, the default BIOS settings apply to most
conditions to ensure optimal performance. Do not change the
default BIOS settings except in the following circumstances:
An error message appears on the screen during the system
bootup and requests you to run the BIOS Setup.
You have installed a new system component that requires further
BIOS settings or update.
WARNING!
Inappropriate BIOS settings may result to instability
or boot failure. We strongly recommend that you change the BIOS
settings only with the help of a trained service personnel.
Quickly enter the BIOS
Windows8 boot time is quite fast, so we developed the following
three ways for you to quickly access the BIOS:
Before booting up the system, insert a straightened paper clip
into the BIOS Reset key.
BIOS Reset key
Press the power button for at least four seconds to shut down
your PC, then press the power button again to turn your PC back
on, and press F2 during POSt.
When your PC is off, disconnect the power cord from your PC's
power connector. Reconnect the power cord and press the
power button to turn on your PC. Press F2 during POST.
Oct 16, 2013 | Compaq Presario 5000 PC Desktop
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Jul 07, 2013 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
Can not enter Phonix BIOS A.07 setup
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Gene Reinhard!
Another key to tap repeatedly when you computer is first powered on is the delete key.
Also some-times USB keyboards are not detected quick enough to actually register your key pressing at the appropriate time. Overcome this by using an older keyboard with a PURPLE PS2 connection.
Take care!
Feb 10, 2012 | Dell Dimension 5150 (DIM515MIN) PC Desktop
How do i enter bios set uo on a sony l640
When you turn your PC on there should be a logo window saying something like "Sony" if you press tab at this screen it should instead turn to a POST screen where your ram will be counted and your drives will be checked, at this window at the bottom of the screen it should say something like "Press button to enter Setup" in the BIOS chip setup is referring to what your referring to.. which is actually the CMOS settings
common buttons for entering CMOS settings is delete and F2
Mar 20, 2011 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
Iam at black screen that said F1 to resume i pressed and sendme to bios utility how can i go back to regular screen windows
What was the error-message just BEFORE that 'F1' message?
Turn the computer off, wait, and turn the computer on.
If you get into BIOS SETUP,
use the "arrow" keys (UP, DOWN, LEFT, RIGHT)
to highlight the 'Load BIOS defaults' menu-item.
Press ENTER to apply that option.
Use the arrow keys to select "Save and Exit from BIOS setup".
Press ENTER to apply.
Oct 24, 2010 | Computers & Internet
How do I acces the Bios on a Compaq Presario 5000 built somehere around 2002.
during the bootup post routines you should see a message that tells you what to do to go into the bios.
Sometimes the post routine is run without being shown on the screen. If so, try pushing the F2 button, or DEL key during the bootup sequence.
Dec 29, 2009 | Compaq Presario 5000 PC Desktop
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
What is the key combination to access BIOS on a Compaq please
mike,
Del key is the general key to enter most of BIOS, but some BIOS has F2 some F10 and few Esc
You can easily see the button on POST screen, i.e. when you power on your PC just see on screen there may be a message like 'Press Del to enter Setup'
Thanks
Iqbal
Apr 10, 2008 | Computers & Internet
IBM NetVista A40 PC Desktop Logo
88 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
