Please try removing battery for a moment (getting cold) and install it again, don't forget to connect charger, after the charge is completed try to turn it on, if there's no motherboard failure the computer should work normally, but if not, maybe you have a "fried" motherboard that needs to be replaced.
SInce the computer is new, the electronic components can bear overheating better, it's more possible that the battery got totally discharged or even damaged, please try to test with another battery. Also read the warranty disclaimers about this kind of accidents or events, if it doesn't mentioned you're covered.
Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
Thank you! I hope the problem's just on the battery and stuff. Is it possible to have a "fried" motherboard even if i just bought it 2 months ago? Anddd do you think that will be covered by the warranty? :(( Thanks again.
