I had my empty color ink cartridge m4646 refilled.when i install it it keeps showing empty.the printeris a dell all in one 922
Bought a new cartridge &installed it. its fine now. my ink filler suplier said that they called dell & were told the cartridge was programed noy to be refilled.
Posted on Sep 05, 2008
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Dell 922 won't print black ink... only uses color cartridge... I can't find selection to use black ink only. The checkbox for print black n white for color is grayed out... Cartridge levels show black ink...
Perhaps the printer does not recognize that a mono/black cartridge is installed. Remove the mono cartridge and check to see that tape is removed then re-seat firmly. Unplug the printer from wall power to reset. Then try again.
Aug 22, 2009 | Dell 922 All-In-One InkJet Printer
Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Mar 24, 2009 | Dell 948 All-In-One InkJet Printer
KEEPS SHOWING LOW INK/
you get from dell 922 all in one software 'replace catridge' option use that option
Feb 24, 2009 | Dell 922 All-In-One InkJet Printer
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
Refill cartridges - need to reset ink level monitors
I must tell you that Dell uses sensors in the ink cartridges and the printer. So one the ink cartridges is low on ink, sensor on ink cartridges will show as low and if you get it refilled, there is no way to reset the sensor to full since Dell does not want customers to use Refilled ink cartridges. However if you are looking for Low cost ink cartridges they I would suggest you to purchase Standard Capacity ink cartridges from www.dell.com/supplies. they are almost half the price for hi capacity ink cartridges.
Nov 06, 2008 | Dell 922 All-In-One InkJet Printer
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Aug 09, 2008 | Dell 922 All-In-One InkJet Printer
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 printing problem
sounds like your ink mixed with other colors only fix replace with new cartridge
Nov 05, 2007 | Dell 922 All-In-One InkJet Printer
261 people viewed this question
jasbo
jasbo
