Question about Electrolux Vacuums
Replacement rechargeable battery pack required for Electrolux Hand held Vac. Model Z77B
4 Suggested Answers
SOURCE: battery charger broken
CHARGER WONT WORK MEC B5265 CAN I BUY NEW ONE?
Posted on Aug 19, 2009
  • 3 Answers
SOURCE: Battery for electrolux pronto stick vac 2 in 1
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
Posted on Dec 08, 2010
  • 3 Answers
SOURCE: Electrolux 2-in-1 Pronto does not hold charge, I
Good luck.
I have a scunci rechargeable wet and dry vac. Model 52069. I plugged it in to charge green light turns on. Couple hours later I unplug it and push the button nothing. Need instructions or manual.
Most likely the rechargeable battery needs to be replaced.
Unfortunately, I haven't been able to find a battery pack listed anywhere. You'll probably have to have a company like Batteries + Bulbs (In the USA) take it apart and replace the battery pack.
Nov 11, 2016 | Scunci Vacuums
I have a dirt devil easy lite for 6 mths maybe.. it charges all day and loses power after 30 seconds.. what is wrong with it.. I cant return it cause I dont have receipt or box
I don't know that vac specifically but it seems to be a low end hand held vac. There is no spec for the battery that I found. That usually means they use a cheap rechargeable and I think the problem is the battery. I would contact the mfr since it is less than a year old. They can verify that from the serial number. If you buy another one, look for a NiMH or a Li Ion battery pack. It will cost you more but it will last a lot longer. Hope that helps.
Nov 02, 2016 | Dirt Devil Vacuums
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
How can I replace the rechargeable battery?
Hi There,
Officially Electrolux don't want to sell the batteries so they discount the price of the hand held unit. Here in Australia they are called ergo rapido but it will be the smae everywhere I would assume. They will sell the battery on its own but it is more expensive than replacing the hand held part (without the filters) .
Jun 12, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Is it possible to replace the battery (loosing charge fast, weak power) for Electrolux stick vac EL 1000? Wher to buy the battery an dhow much cost? Thanks LJ
Jan 12, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux 2-in-1 Pronto does not hold charge, I believe it's a battery problem. How do I get then replace the battery, since it is located in the hand vac part of the vacumn?
Good luck.
Jun 28, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Hoover Freejet Cyclonic will not charge after battery run flat
basically, the batterie pack is shot and it will cost about £40.00 ish to replace. as you said, a right rip off
Dec 24, 2008 | Vacuums
This battery works perfect too (for your model), take a look on amazon: Amazon com tenergy 2 3a 1600mah nimh. Cheers
Dec 22, 2008 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Vacuums Logo
132 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
