Question about Dual XD7600 CD Player
Face gets stuck & can't use controls
I've had this unit for a while now, and I should have returned it when after about 2 months it started acting funny. Now its so bad that I can't change CD's or see the display. If the face actually does come down & I can see the display, it doesn't help because after that the controls are useless until the car is shut off & restarted again, when the faceplate goes back up itself. I can't turn it off, turn the volume up or down, change the station or skip a song... nothing.
  • 3 Answers
I was told by manufacturer that is called a cable ribbon and cost about $30.00 thru dual electronics.
Posted on Sep 02, 2010
Front load washer stuck on final spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
The gas gage on my '97 Subaru Outback Wagon works sporadicly. I've had the sending unit replaced twice and the gage works well for about 3 months and fails again.
if the sending unit has been replaced and it works for a while then acts up again check the electrical plug and connections also look for a broken wire or nicks in the wires coating as corrosion inside the wire will cause a problem that circuit works by resistance not voltage
Apr 13, 2012 | 1992 Subaru Legacy
My LG steam dryer is stuck on pause. I've tried unplugging it and re starting. I've tried the other buttons. Nothing works. Help!
Possible that the processor in the main controller unit has hung up. If there is no result even after the power plug is removed for few hours or even overnight, it is possible that the controller unit has failed.
need to confirm if you able to source one for a test before you order or invest.
Oct 18, 2011 | LG Dryers
I bought a 1981 Yamaha 750 seca and I've had it for about a month. I was riding one day when it started revving really high as I was downshifting when coming to a stop. It is now stuck in first gear....
Hi, 750seca and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
XJ550 Maxim won shift gears
81 yamaha seca 750 shifting problems
Yamaha XV535 Owners Workshop Manual
OEM parts for Yamaha
YAMAHA XV535 Owner Manual
Aug 23, 2011 | Yamaha Motorcycles
The L button is a little looser than the R button. Is it normal???
As long as it returns to its normal position and doesn't get stuck or the like this is ok. It could indicate that that button is becoming worn tho. Tho, all the buttons are made to be the same in the factory every control I've had for all platforms or pc has been slightly different in feel. I wouldn't worry much about it unless it actually starts acting worn out and sticking or not activating.
Jun 25, 2011 | Nintendo DS Lite Console
I installed a Heat-n-Glo 6000GLX with wall mount control 4 years ago. Has been trouble free till this year. Actually problem may have started last year where the flame would light then flame out in 3-5...
sounds like your control module is defective, put you hand on the control unit and see if you can feel the noise.
Please Rate/Vote this response. Thanks
Dec 20, 2010 | Heating & Cooling
I have a Keurig B60 for about a month now and it's starting to give me some issues... 1) after brewing a cup of coffee, the motor in the unit will continue to run for a good minute and then shut-off...
It should still be under warranty if you only purchased a month ago. I have a friend who had problems with this machine after 3 months. She contacted Keurig at www.keurig.com and they were very accommodating and sent a replacement unit. She says so far so good with it.
Aug 08, 2010 | Keurig B60 Coffee Maker
Xbox360 premium console.
send it back to microsoft doing anything to the console will void the warranty
Oct 18, 2008 | Microsoft Xbox 360 Console
Dual XD7600 CD Player Logo
94 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
