Question about Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop Problem
I have adell gx520,when i connect the power cable,the power light blinks amber...and when i disconect the processor power cable(aux..12v)...the power button lights amber but does not blink...and the fans are all rotating....what can be the problem?
  • lawrelochi Oct 26, 2008
    am gladfull for the solution.....thou i replaced 2 mosfet transistors that power the processor....and it worked...its up and running
  • Anonymous Mar 30, 2014
    wont power up, no power button lights
  • Dell Master
  • 998 Answers
An Amber blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 20, 2008
Hello everyone, check your cpu - I've just had one of these in for repair and the cpu was faulty - removing the ATX 4way 12v lead let the pc start rather then detecting a short and shutting the psu down. Changing the cpu cured the fault.
Thanks
Posted on Apr 18, 2009
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Dell optiplex mini tower, when turn on the computer amber led lights blink with a , and will not startup
If the power light is blinking amber - The computer is receiving electrical power, but an internal power problem might exist.
Apr 25, 2014 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop won't power on
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jan 31, 2014 | Dell OptiPlex GX520 PC Desktop
Yellow light on the power button of my Dell Optiplex GX520. I've tried: 1. Replaceing the power supply 2. Replacing the CMOS battery 3. Removing and reinstalling the RAM memory. 4. Replacing the...
A solid orblinking Amber power button indicates a voltage problem. This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Sep 18, 2011 | Dell OptiPlex GX520 PC Desktop
Where is blinking amber light located on dell
Replace CMOS Battery.
1. Locate your CMOS battery
2. Obtain battery information
3. Removing the battery
4. Removing the battery
5. Enter CMOS values
This link will guide you. CMOS
Thank you for posting..
Jun 30, 2011 | Dell OptiPlex GX520 PC Desktop
My GX520 was shut down as usual last night...I turned on this morning and I get nothing...just a little yellow/amber light blinking where it is normally green....help
Here is the info straight from Dell. looks like you have an internal power issue. You will most likely need to contact Dell directly for assistance, they are pretty good about giving support even if the system is no longer covered under warranty.
  • Ensure that the voltage selection switch is set to match the AC power at your location (if applicable).
  • Ensure that the processor power cable is securely connected to the system board.
Dec 28, 2010 | Dell OptiPlex GX520 PC Desktop
When i turn power on my dell gx520 just blinks yellow and nothing else, nothing else at all
If the power button light is blinking yellow . Generally it means the problem is with the power supply and needs to be replaced . If after replacing the power supply the problem is not solved it would be the motherboard failure.
To know more on how to troubleshoot the system visit the following link
Dell support site link
Thank you for using Fixya
Proton
Oct 08, 2010 | Dell OptiPlex GX520 PC Desktop
My amber light is blinking
The hard disk is being accessed, this is normal. However, if the computer is idle (not doing anything noticeable), then this may be a virus infection. Get Malwarebytes and run a scan.
May 05, 2010 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
1,777 people viewed this question
Alun Cox
