Question about NEC MobilePro P300 Pocket PC
Remove the LCD protection cover
How do I remove the LCD protection cover?
    Master:
  • 903 Answers
There are two round pins on the top of the MobilePro P300 protection cover. You must pinch the two pins together in order to release the hinge and remove or replace the cover from the unit.
Posted on Sep 15, 2005
I have a canon mx860 and im getting a error code c000
the print head is blocked?
Cancel printing and turn the machine off. Then remove the jammed paper or object that blocks printhead.
NOTE
If you have not removed the protection, follow the procedures below.
1.Open the output paper tray.
2.Lift Scanning Unit (cover) until it stops.
The support of the scan unit is automatically locked.
3.Remove the orange protective tape (A) and the protective packaging (B).
4.Ensuite, slightly lift the scanner unit (cover), fold the support of the scanner unit and then gently close the Scanning Unit (Cover).
CAUTION
* Do not touch the components inside the machine. The machine may not print correctly.
Put the machine on.
Dec 16, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I am trying to remove the tv stand base off my 42lg30. Can someone please help!
DETACHMENT
Carefully place the TV screen side down on a
cushioned surface to protect the screen from
damage.
Loose the bolts from TV.
you can view a larger image by clicking on this link then selecting the Manual on the right hand side
the information you will need is on page 13 of the manual
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Detach the stand from TV.
After removing the stand, install the included
protection cover over the hole for the stand.
Press the PROTECTION COVER into the TV
until you hear it click.
Dec 03, 2010 | LG 42LG30 42 in. LCD HDTV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
Instructions:
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Is it possilble to repair a scratched lcd tv screen
Hi
Typically, all lcd screens have a protective film coating that is scratched is not the matrix. If the scratches are not deep you can try them polished tool for polishing cd drive. If you scratch deeper and you will not be able to remove them yourself, contact a service center to replace the protective cover the screen it will cost a low price
Sep 18, 2010 | LG 30FZ4D TV
How to open the flat screen
Francois, If you really want to remove the pedestal and then rear plastic cover from the front BEZEL, then why don't you visit YOUTUBE and view some video clips of "LCD monitor disassembly" and "LCD monitor repair" to see how to "PART" the cover from the bezel!!! There sure is a lot of stuff to see on YOUTUBE. HINT!!! YOU must protect the LCD PANEL at all times!!! GOOD LUCK, 12fixlouie
Dec 11, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
My n70 is just vibrating and not ringing and is
The LCD display connector is either loose or the LCD is faulty, the speaker contacts are loose or the speaker is faulty.. Other than that, you have to have it checked by a qualified technician. Follow the procedures below to disassemble the phone and check the LCD, connectors and speaker.
  1. Wear a pair of electro-static discharge (ESD) protective gloves.
  2. Unlock and remove the battery cover.
  3. Unlock the clips of the front cover beginning at the bottom by prying the latches with your fingernail or a prying tool one at a time.
  4. Carefully remove the front cover.
  5. Protect the display with a plastic film.
  6. Remove the 6 screws using a T6 screwdriver.
  7. Swing the user interface (UI) frame assembly upwards from the bottom. Bear in mind that the flex connector is still connected.
  8. Disconnect the flex connector carefully by prying it.
  9. Clean the connectors using a soft-bristle toothbrush with a lacquer thinner.
  10. Remove the engine board and place it in a cushioned non-conducting tray.
  11. Clean the speaker terminals and contact pads on the engine board using a cotton bud with lacquer thinner or alcohol.
  12. Lift up the speaker terminals to ensure it makes contact with the contact pads on the engine board.
  13. Check the resistance of the speaker using a multimeter. The resistance reading should be 20-30 ohms, otherwise replace speaker.
  14. Put back the engine board.
  15. Reconnect the flex connector firmly and reassemble the UI frame assembly.
  16. Remove the protective plastic film and reinstall the front cover.
  17. Insert the battery and turn on the phone.
  18. There should be a display and tone when the hands appear on screen. Otherwise, have your phone checked by a qualified technician.
Check this out for the complete disassembly:
Nov 24, 2009 | Nokia N70 Cellular Phone
How do I take stand off
damage.
Remove the 4 M6 bolts by the CABLE MANAGEMENT CLIP.
Jul 09, 2009 | LG 42LG50 42 in. LCD HDTV
LN37A550 FLAT SCREEN TV
To remove the base stand, place the TV face down on a smooth surface. Place a cloth underneath it to protect the screen. Remove the 4 phillip screws from the stand. The stand can now be removed. The set can with a cover plate you can use to cover the opening.
See page #86 in the User Manual.
Mar 15, 2009 | Samsung LN37A530 37 in. LCD HDTV
How to change lcd screen on motorola pebl u6?
As on most Motorola phones, the lens that covers the main LCD must be carefully removed to access the screws underneath to pop off the exterior faceplate. Once that is done, there is a silver main casing that protects the LCD. Pry up the side to remove it. You will then be able to access the LCD for removal.
Mar 11, 2009 | Motorola Mobility PEBL U6 Cellular Phone
Dog Hair under protective coating on monitor
get your Dell manual out and look in the index for lcd cover. It should tell you how to take it off and maintain it. If things get behind it it should be removable. Also www.dell.com is very informative with their support group.
Sep 13, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
NEC MobilePro P300 Pocket PC Logo
248 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
