Question about Lite On Televison & Video
My computer doesn't recognise my D: drive when I click on My Computer
  • garyfhumes Sep 04, 2008
    I can use the drive by typing in D:, but I'm wondering if something inside the dvd drive has unplugged.
    this is an internal dvd drive
    Sergeant:
  • 264 Answers
You have not mentioned that which operating system youare using. I am providing you with a link of Microsoft. Just followthelink and i am sure that the issue you are facing will be resolved.
Click Here
Thearticle may have a different heading however this will resolve theissue you are facing. Follow the steps and delete the upper and lowerfilters.
All the Best
Sammy
Posted on Sep 04, 2008
    President:
  • 1,952 Answers
Go to address and click drop down list box ...which is present in right side cornor of address bar...it look like inverted triangle...click tat...u ll get a list..from tat u select d drive ...it ll get open
  • 10,594 Answers
If D drive is in list on My Computer then drive is faulty. If its not there in My Computer, perform BIOS setup and recognize/enable drive there.
    Scholar:
  • 125 Answers
I'm having the same issue! It will open and close and light will blink for only a moment then go off. Then, just as you, it will not read as if I have a disc in when I click on my computer. If I click on the cdrom drive, it says PLEASE INSERT A DISC. I'll be checking back to see if anyone knows how to fix. :)
  • 446 Answers
Is this a internal device or external device?
  • 83 Answers
I advise you to buy another
Computer wont recognise external hdd
Follow these steps:
1. right click on My Computer
2.Click on manage
3.Click Disc Management
There you can see External hd (you can chose to activate or change drive letters and that will do the job)
Mar 29, 2013 | Buffalo Technology DriveStation HD-HC500U2...
Transcend 16 gb pendrive is not recognised
Right-click on COMPUTER. Select PROPERTIES, Go to DEVICE MANAGER. Under UNIVERSAL SERIAL BUS CONTROLLERS, check all the USB ports to see if they are working properly. If the USB PORT in which you have inserted your pen-drive, is showing an error, right-click over it and select PROPERTIES and make a TROUBLESHOOT.
If this troubleshooting doesn't help you, use another computer to check if your Pen-drive is working there. If the problem persists, go to the manufacturer's service center and ask for a replacement or repair.
Hope this helps, Mrityunjay.
Jun 25, 2012 | Electronics - Others
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
My PNY usb key is not recognised. Gets intalled fine, can see files in Device manager but disk 1 says "no media". computer doesn,t recognise usb is plugged in
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Feb 16, 2011 | PNY USB SmartMedia Reader PC (SFRUSBWB)
While transfering a file from pc to hd computer froze. I then unpluged the drive and then pc come back to normal now the external will not get recognised
It sounds like you have a serious problem. If you cannot get the HDD to read at all and your computer will not recognize it, you have a bad "sector" of the drive.
As a metaphor:
Your drive has little "squares," each square stores information on it. Your computer will break the data down into these squares and store it in segments. When your computer freezes its because it is "confused" as to why it cannot store the data. When you remove the HDD, the computer then assumes it's to stop and resumes regular activity.
The solution:
A) Go to “My Computer” right click on the Hard Drives icon and go to “Properties,” then go to “Tools” and then to “Error Checking.” Also then “Defragment”
If that doesn’t work:
B) Try to reinstall the updated drivers on the manufactures web-site. After you have reinstalled the drivers reformat the Hard Drive. Reformat your hard drive by going into "My Computer" and right clicking the HDD and selecting "Format." Follow the prompt.
-Paul
May 21, 2010 | SimpleTech Signature Mini 250GB External...
I put my old hard drive in as a slave, vista recognises it in management and device manager but doesnt recognise it in my computer?
it might need to be formatted, right click on the computer and click on manage, click on disk management and format the disk.
Mar 03, 2010 | Acer Aspire m5640 PC Desktop
Right click on 'My computer' and select manage and there you will find the option that is "Disk management".You can change the drive letter there..
Sep 04, 2008 | Lite On LiteOn 16x Black internal oem DVD...
My computer doesn`t recognise disk in dvd drive
1. Make sure you use DVD's in good condition.
2. Reinstall the driver..( right click My Computer->properties->Hardware tab -> Device manager-> DVD rom-> right click Uninstall and again install using Dvd rom driver cd)
3. Clean The Drive lens using Dvd lens cleaner disc kit available in maket.
4. Removing DVD rom. opening it up manually and cleaning the lens with cotton( this tedious for novice users.. instead give it to servicing shop)
May 20, 2008 | Toshiba Computers & Internet
Televison & Video Logo
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
