Question about JVC Sirius KD-LH300 CD Player
JVC KD-LH300 Wont Work
I recently removed the face plate of my unit and kept it off for about 3 days as I was having a window replaced in my car. Once the window was fixed I put the face plate back on. The face plate went back to its pre-set angle but thats all it did. The display screen would not light up. It is getting power so I know thats not the problem because I was able to eject a CD I had in the unit. I also hooked up an older model JVC unit into my car and it worked fine. I also pushed the reset button on it to see if that would help, again nothing. All I hear in my speakers is static. I think it may be stuck on antenna mode. Ever heard of a problem like mine ?
    Genius:
  • JVC Master
  • 1,550 Answers
Clean the parts on the connector between the faceplate and the stereo maybe get dirty
Posted on Sep 06, 2008
I have a jvc kd-lh300 when i insert a cd it shuts down is there a fix for this
It is important to know if your battery is holding 12v. Because it turns off when mech is used can mean your battery is low and radio is pulling too much current. If you tested this with another battery or on a power supply and continues to happen, this is an internal issue.
Feb 09, 2015 | JVC Sirius KD-LH300 CD Player
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
Cannot access door latch assembly 2009 JEEP LIBERTY
all this is covered in the FSM. step by step. under body or doors.
2nd best is alldata.com
what door? you never said and steps can very by body options.
name the door,
i guess the latch is bad?
here are the words, for door lock motor.
lots of steps. my wild guess , it the door cover is off.
and the plastic film removed
and you get stuck here,
  1. Remove the tape covering the access hole on the carrier plate and discard. Access the window regulator liftplate through the hole in the carrier plate.
  2. Push down the door glass (1) and use a slotted screwdriver to release the tab on the window regulator liftplate (2). Lift the glass up and secure to the header.
  3. Remove the three screws (2) securing the door latch to the door shut face.
  4. Remove the one screw (1) attaching the latch bracket to the door shut face.
  5. Disconnect and remove the electrical connector (1) from the door (4).
  6. Remove the 10 screws (3) from the carrier plate (2).
  7. Disconnect the outside mirror electrical connector.
  8. Remove the carrier plate (2) from the door (4). end
once carrier is out there is chapter on that , disassebly
really, buy the FSM
or log in to alldata.com
and avoid making wrong moves, or getting hurt.
Apr 02, 2014 | 2009 Jeep Liberty
What does DCP stand for?
[Detachable Control Panel].. Which is your face plate.. I take your having trouble , remove all disk USB mpe attacehed remove face plate you will see a little hole you will need like a paper clip to push the button for about 2 seconds to reset the unit. after resettting attach face plate and try unit.
Feb 25, 2014 | Clarion CX609 Car CD/ MP3 Player
Is the KD-LH300 bluetooth ready?
The KD-LH300 lacks BlueTooth and cannot be service modified to include BT either.
Please take a moment to rate my free answer to your question.
Sep 24, 2010 | JVC Sirius KD-LH300 CD Player
A problem started with my Panasonic CQ-C9700N car stereo recently which involved the complete facia powering off. However the stereo would still work in the mode it was left in. Every now and then it would...
if im not mistaken, that model has a detachable face plate. What happens a lot of the time is the connections between the face plate and the unit get corroded. Take the face plate off and (with fine grit sand paper) lightly scuff the electrical connection clean on both the unit and the face plate. It also doesn't hurt to use a little dielectric grease before you reattach it... this method has work several times in the past for me... Hope this helped!
Apr 29, 2010 | Car Audio & Video
How do I replace the LCD screen on my Sony
Hi axim5721,
Please don't remove the face plate off yourself, even if a bit gets broken it wont fit again, the screen of LCD screen on sony is very sensitive,, so take it to the repair ,, only they know how to replace it,,,,,,
good luck with your fix,,,
have a nice day,,
Regards
Arul
Mar 06, 2010 | Sony Ericsson W760i Cellular Phone
Just installed an XDM7615 Dual stereo and the face plate won't detach. Can anyone help? The manual says there is a button behind the face when it's in the 'eject' position but pushing this button does...
There are 2 very small screws on the back of the face plate that need to be removed. Once these are removed, you may then remove the face plate.
Feb 10, 2010 | Car Audio & Video
JVC Sirius KD-LH300 CD Player Logo
350 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
