Question about Sony DAV-SC5 System
High pitch Ringing
There is a high pitch ringing coming from the speakers.I used to go away after the unit was on for 10 or 15 minutes but now it is constant.
I tried disconnecting and replacing all of the audio and video cables but no change.I Also disconnected each speaker to see if was just a bad speaker nut no change.
    Scholar:
  • 55 Answers
Does the ringing happen when listening to the radio, CD, or both?
Posted on Sep 04, 2008
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Surround sound troubleshooting
The ringing is a power supply that has gone into protect mode due to a fault.
It needs to be sent for repair.
Jan 19, 2018 | RCA Audio Players & Recorders
High Pitched ear ringing sound coming thru somewhere up front by navigator system
Some things I would check are do you have blue tooth in operation. Do you have any form of michrophone in the cab as it sounds like a feed back problem coming through your speakers. Talk to a radio techie to see what he thinks
Feb 23, 2013 | 2008 Jeep Grand Cherokee
High pitched ringing sound from my tv
It most likely is coming (based on model number listed here) from the high voltage transformer---ways to silence that up to and including replacing that part.
Jun 16, 2012 | RCA HD52W59 HDTV Projection Television
you could invent a replacement rubber washer for the motor unit, a more compliant washer will work (trial and error im afraid )
Feb 04, 2010 | Refrigerators
Panasonic KX-TG5632 one handset high pitched constant ringing
you are getting feed back because of too high of a level. Turn your volume down on that handset and the squealing should go away
Dec 27, 2008 | Panasonic KX-TG5632 Phone
High pitched ringing when LCD is on
Obviously it's crosstalk from the supply for the LCD backlight supply into the audio amp...it's odd, because the supply should feed LEDs rather than a CF...but I'm thinking maybe a label in the phone got wet and is conducting your whine over to the audio bits.
The general solution is to crack the case, find the audio circuits, and make sure there is no deposit linking the areas such as from water condensation, spilled coffee, soaked label, etc. You can hear when you've fixed it!
Aug 15, 2008 | T-Mobile Wing™ Smartphone
Nad c520 high pitched ringing
Hi, From your description, it sounds as if the noise is coming from the circuit that controls the display backlight. If I recall correctly, the C520 has an EL backlight just like the C521 (which I have one of). On the front of the circuit board, there should be a little yellow trimmer potentiometer that controls the brightness of the display. It may be that the noise will go away if the brightness is turned down some. If  the noise varies as you turn the controller, but doesn't go away completely, the backlight may need servicing.
Aug 06, 2008 | NAD C521 CD Player
Symphonic 32 flat panel ringing problem
that high pitched ringing is usually caused by a power leak in the high voltage section of the set. it needs to be looked at by a proffessional electronic technician before it goes out altogether.
May 09, 2008 | Televison & Video
Ringing sound with fan?
That high pitched ringing sound is a faulty colourwheel that will need replacement.
Apr 07, 2008 | BenQ PE8700 Multimedia Projector
Sony DAV-SC5 System Logo
231 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
