Question about Sony KV-32FS13 TV
Sony TV no sound
No sound - mute and audio settings checked.
  • bradowitz May 23, 2009
    Sony Bravia TV: when using DVR to pause or rewind program, audio works but sometimes lose sound. Checked mute and audio program - all shows normal and not muted. Tried changing channels and all channels muted. Resolves itself after a few minutes, but very irritating. Anyone know how to fix this?
  • 57 Answers
First open the rear cabinet,if you a tester first test your speaker both side if open ,second check the voltage of the resistor if has a 12 volts going to audioutput.and third if speaker and resistors are good.you to replace the audio output.
Posted on Jan 11, 2009
I have picture, but no sound
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
May 10, 2015 | Sony KV-27V35 27" TV
I have a Luxor tv LUX0165001/01. My child sat on the remote and since then the sound does not come out properly sounds all muffled and tv is also making clicking noise, I have re tuned it and checked sound...
Feb 14, 2015 | Televison & Video
MY SONY KV 2192M3 NO SOUND
Check its speaker/s first. Check whether the audio is muted or not. If all are OK, check and replace damaged component/s at its audio output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 11, 2014 | Televison & Video
When switched on there is no sound at all
Check the audio settings. Whether it is muted or volume is at '0' stage. Check the speakers. Check the audio output section circuit.
Jun 17, 2013 | Sony FD Trinitron WEGA KV-32HS500 32" TV
No sound is coming out of my tv
Check whether mute function is on or not. Enter its sound menu and check it. If it is not off there, the fault is with its audio processor section, mute section, or audio output section. To make it confirm, your set need a through checkup. Contact any experienced service technician.
Feb 15, 2013 | RCA Televison & Video
No audio on Sony Wega Tv. Mute is ok. Volume bar goes up and down . No sound at all
Hello, Welcome to Fixya.com
If the mute is ok, you want to check if your have a cable or sat box that the mute on those are ok as well, if so then your looking at a internal issue with the TV that would involve repair.
Try this
1. unplug the tv wait 10-15 seconds then plug it back into the wall outlet.
Also
2. unplug any cable boxes or sat boxes that might be causing the issue.
If you still are having issues you might want to check it into a local repair shop near you, but take this advice for what its worth you might wind up paying more for the repair then the purchase of a nice flat panel.
Make sure if you do take it into a shop that there registered with the BBB and do not have complaints registered as those shops could end you paying more money.
Thanks for making Fixya your first choice, We can Fix most things but have solutions for everything.
Regards,
Rulds2008
Mar 22, 2011 | Sony FD Trinitron WEGA KD-36FS130 36" TV
LG 32LX3DC TV sound stopped working
Hello cadillaczacc,
This could be you audio out put stage malfunctioning. As a test connect a head set to you RCA connectors for audio (Red and White RCA Audio out jacks) and see if there is sound (there should not be if the audio amp has malfunctioned). In addition check your setup menu to make sure the TV is not on mute mode. If the TV is not on mute and you do not hear sound from the headset connected to the audio out RCA jacks, then we can start looking at the possibility of an internal circuit problem.
I have the schematic so if you need help, and have a background in electronics, we can get this fixed. If you do not have a background in electronics I would suggest getting a qualified TV technician to fix this TV for you.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 08, 2009 | Sony KV-32FS13 TV
No Sound Issues
Hello!
Try the audio out. Run the audio to a receiver to see if the audio is there. If it is, then I'd leave it hooked up to the receiver and save yourself some money. If there is not any low level audio out then I'd fix the set. The only Sony set I've ever seen that was not worth fixing was a 32" model from the early 1990's that had bad picture tubes after only 5 years. I am a Sony factory trained tech. Good Luck!
barneyluc
Oct 13, 2008 | Sony KV-32FS13 TV
Audio
Hello storymn,
This problem looks as if it can be you audio output amplifier stage of your TV. Also I would suggest shecking your remote and setup menu to make sure you are not in mute mode, this has happened at times. So your troubleshooting checklist is:
1) check the setup menu and remote to see if the TV is in mute mode
2) if you have the equipment check the audio at the output jack and the speaker.
3) unplug the set, take the back off and inspect the connections to the speaker.
*Only do the following if you have a background in electronics
4) Plug the set in and with a small audio amplifier check the output of the audio output stage if sound is present the check the circuitry on that path. If there is no sound the audio output IC or amplifier should be suspect in causing this problem.
I hope this helps,
Thank you,
Shuttle83
http://www,electron-age-technologies-llc.com
Sep 03, 2008 | Sony KV-32FS13 TV
Sony KV-32FS13 TV Logo
1,600 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
