Television sony 21 inch
Shorted power supply
  • 10,594 Answers
Please mention exact model number of your Sony 21" TV to provide you technical help.
Posted on Sep 04, 2008
Sony TV set, KV20FS120 BA6 chassis: light blinks, set isn't coming on. Why?
Sony sets like this have a built-in self-diagnostic function.
The blinks of the Standby LED are the self-diagnostic codes.
There may be more than one error. The blinks indicate only the first error.
Unlug the set. Wait 30 seconds.
Prepare to count the number of times the Standby LED blinks.
Plug the set back in. Count the blinks.
2 blinks
  • Diagnostic Item Description: +B overcurrent (OCP)
  • Probable cause:
    • H.OUT (Q506) is shorted. (A Board) (20"/21" models only)
    • RGB Amp (IC1751) is shorted. (CV Board)
  • Detected Symptoms:
    • Power does not come on.
    • Load on power line is shorted.
4 blinks
  • Diagnostic Item Description: I-Prot
  • Probable cause:
    • +13V is not supplied. (A Board)
    • IC545 is faulty. (A Board)
    • Has entered standby state after horizontal raster.
    • Vertical deflection pulse is stopped.
    • Power line is shorted or power supply is stopped
5 Blinks
  • Diagnostic Item Description: IK (AKB)
  • Probable cause:
    • Video OUT (IC545) is faulty. (A Board)
    • IC001 is faulty. (A Board)
    • Screen (G2) is improperly adjusted.
    • No raster is generated.
    • CRT Cathode current detection reference pulse output is small.
The above may be of little help. Your best bet is to download the service manual for the KV20FS120.
...Google search: Sony KV20FS120 service manual
Apr 26, 2016 | Sony Televison & Video
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
When i switch on 21 inch lg tv the voltage in power supply section continuously falls to 0.2 and tv wont power on
Short circuit at the main board. Check the horizontal scan output transistor for short circuit. Check its collector to emitter, or collector to base for short. Replace this transistor and check. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | LG Televison & Video
Sony trinitron 21 inch kv g21q1
It means that one of the secondary output voltages are short. You ll need to check every output voltage at the smps transformer. If the set is producing a hissing sound, then either the 115 v zeener is faculty or the horizontal output transistor is faulty
Jan 15, 2014 | Televison & Video
Sony tv 21 inch horizontal output transistor failing frequently
• Power Supply B+ is higher than normal
• Partially shorted Flyback Transformer
• Bad Deflection Yoke
• Too much oscillation on the Jungle IC
• Bad capacitors around the horizontal output transistor
Sep 27, 2012 | Jwin JV-TV9090 21 inch TV
My 25 inch Sony CRT TV turns off by itself and blinks twice several times.
Hello
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Its power supply regulation board has the trouble. Check for any loose soldering points in it. Resolder most of the suepected solder terminals by applying a little more solder. This is a common fault to Sony power supply system board. OK
Jul 07, 2011 | Televison & Video
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
TV: Sanyo 21 inch tube (about 10 years old) When TV powered on. When I try to manually or using remote bring picture on (i.e. by prg up or down), the power on indicator light starts flashing and nothing...
You have a power supply problem.
The microprocessor has its own supply and is not receiving a "hand shake" from the line output stage that in turn is not receiving and power from the power supply.
The chopper transistor will possibly be short circuit taking the feed resistor with it.
Check for dry joints everywhere and MAKE CERTAIN THE HT CAPACITOR HAS DISCHARGED!!!!!
Hope this helps.
Oct 30, 2010 | Sanyo DS31520 31" TV
Sound missing
helo try to short the spider transistor along ic amplifier. it is in a mute
May 21, 2007 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
