What kind of wet? Is the wetness gas, oil, or water? There are different types of fouling possible with reading the color of the old plug being a good indicator. Is the compression within limits?
Check your intake manifold by taking it off and comparing the ports going into the head. If the intake port on #4 cylinder is wet there may be a problem in the Intake. You will also be able to look at the intake valve stems on most motors. The newer designs have the water going into the block directly so the Intake contains no water.
You could have a bad oil seal on the valve stem. You could have a head gasket leak. Even some oil rings can still sling oil and if the power rings are good, it still will compress and give good readings.
You need to run the motor again and try wiping the plug again to see what kind of deposit is on it.
