Question about Ryobi 120 V Detail Sander
Ryobi R165 Router switch
The switch used to lock and unlock the chuck switches from unlock to lock and the router shuts down.
  • 1,996 Answers
I'd say it's time to replace it or get a new router. Sounds dangerous to me.
Here's a link to a parts diagram and list if that will help you out somehow...
Ryobi parts
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
How do I change bits on a Ryobi Router R165
if it has a spindal lock . you hold that in and loosen the nut around the bit
Sep 12, 2014 | Ryobi R160 Routers
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Mar 23, 2014 | Freud FT2000E 3 Router
Hi i have a ryobi r / 150 router which i,ve broken the collet chuck and bit adapter where can i buy them from,i live in victoria. kind regards dave.
Check here ->
They handle just about everything, don't let battery tag deter you.
Mar 03, 2011 | Ryobi ROUTER KIT P163K
I'm new to home improvement, and just bought my first cordless drill (Ryobi P204, 18-volt, 1/2"). How the heck do I insert the bit? The drill comes with two batteries, and a charger. There is an opening...
Like many drills these days, the P 204 has keyless chuck. In order to secure a bit, locate the forward/reverse switch (right above the trigger). Set it to the center of the three positions. This will lock the drill so that it cannot turn. Now turn the black portion at the front of the drill's nose (looking at the drill from the front, clockwise rotation will tighten the chuck and counterclockwise will loosen it) Adjust the chuck jaws so the bit you have chosen will fit without too much slop and then tighten the chuck until it holds the bit snugly and straight. Unlock the forward/reverse switch (push to the right to drill or insert screws) and you should be ready to go!
Oct 24, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
My Ryobi router is not working at all. It spins
It can be any number of things that cause this:
1. Broken power cord
2. Failed on off switch
3. Failed trigger switch
4, Brush or brush tube assy failure (Most common failures)
5. Open armature winding
6. Open field winding
If you can not get continuity across the power cord with the switch on and trigger switch depressed yhe only option for further troubleshooting is to open the unit.
You can go to this page then click on go to power tools store and under model number use R161
The manual lists all 50 parts in your unit.
Item 16: Brush assy part # 968304-026
Feb 04, 2010 | Ryobi ROUTER KIT P163K
I have a Ryobi RE175. It just stopped working
1. Shut the power off, and disconnect your Ryobi
router. It could be the start/stop switch. So, you
can begin checking the switch contacts using the
multi-tester. Set if at 1 x 10 Ohms. Put the probes
of the tester across the switch terminals. Pressing
the trigger on will move the tester indicator to zero
if your switch is okey. Otherwise, no moverment -
the trigger switch need replacement.
2. Should the trigger switch proved to be okey, Check
the carbon brush of the unit, short carbon brush??
you have to replace it.
Nov 03, 2009 | Electrical Supplies
Collet chuck for Ryobi router R150 was broken
Ryobi - Sydney phoned and they had the part available so proceeded, thanks
Allan Japp
Dec 16, 2008 | Ryobi Laminate Trimmer Kit
Chuck on Drill not moving
Re: Ryobi P205 special from Home Depot:
Confusing at first, but easy fix:
The chuck is shipped in the UNLOCKED position (and tightly unlocked, too).
I gripped mine w/rubber gloves and turned toward LOCK direction. It freed up with some effort.
But that's the trouble, it is a bit confusing because you would think you need to unlock it, but it's already unlocked.
Sep 02, 2008 | Drills
your router have reset switch just press, then off router and on.
May 29, 2008 | 3Com (3C16593BN) 24-Port Ethernet Hub
Ryobi 120 V Detail Sander Logo
417 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
