Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Does not drain water after wash/rinse cycles
My dishwasher does not drain after the wash cycles. Water sits in the bottom of the washer and is not pumped out.
  • 3 more comments
  • Anonymous Sep 08, 2008
    My water doesn't drain out after running.
  • nevacloe Sep 29, 2008
    I'm having the same problem. Dishwasher goes through all the cycles and
    says the dishes are clean, which they are. It's just that 1-2 inches of water
    stays in the bottom of the dishwasher. Took the drain hose off and it does
    not appear to be clogged. My husband is a "Mr. Fix-It" but has no knowledge
    or experience with dishwashers! Is it time to call the repairman?!
  • Anonymous Oct 09, 2008
    water will not drain after the cycle is complete. The dishes are clean.....
  • Anonymous Apr 03, 2009
    My water isn't draining out after cycle is complete. HELP!
  • ladyamg3 May 11, 2010
    How do I get to the parts you said we should check?
    Genius:
  • 1,605 Answers
Check the drain pump at the button of the dishwaher.
its not a big job, but it is a pain to take it out.
once you have it out, take a look of the bland on the motor, make sure they are all there, missing bland will cause the water to bunce back and nto drain completely. take a look of the motor, it should turn freely. the pump is oneway. make sure nothing else is broken from the pump and the outlet.
if all failed, replace the pump.
Posted on Oct 28, 2008
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
My GE Adora dishwasher is not cleaning well and the detergent isn't completely disolving. What could be the problem?
Mine has been doing the same thing for about 2 months now.. I tried Finnish brand diswasher cleaner, but to no avail. Try this:
1) Empty your dishwasher, then take out the lower rack.
2) Start a regular cycle. Wait until you hear the jets turning, then open the door. Make sure there is enough water in the bottom - It should be just UNDER the heating element.
3) If your dishwasher is getting enough water, Reset your washer and allow it to drain.
4) Go to the store and get a gallon jug of white vinegar. Start your dishwasher on a regular cycle.
5) Once you hear the jets turning, Open the door and add FOUR CUPS (liquid measure) of white vinegar to the water in the bottom. Let the wash cycle complete.
6) When the wash cycle drains, the rinse cycle will fill. Once the rinse cycle starts, add ANOTHER FOUR CUPS of white vinegar to the first rinse cycle.
7) Allow the first rinse cycle to drain. Let the second rinse cycle complete normally.
I know this sounds too good to be true, but it REALLY DID work for me, this evening as a matter of fact! I also bought some hard water/soap film detergent additive from the store. It was kind of expensive, but I'm using it for a while just in case.
I hope this helps. Like I said, I couldnt believe it when my dishes came out clear again! Also, I turned OFF the heated dry cycle, and just opened the door and pulled out the racks when it was done.
Good Luck!
Mar 30, 2010 | GE Adora GHDA654LBG Dishwasher
Water not draining during rinse cycle
check the drive belt for the pump under the machine
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Water will not drain after wash or rinse cyles
sjjordan96,hey just had the repair guy come today. The problem is the one way valve on the washer was clogged. Its easy to get to just remove the bottom panel of the washer and disconnect the drain hose and clear the clog.
Jan 23, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwasher will not drain water. Put Drain-O in did not work,ran short cycle water on floor. HELP
My Whirlpool Diswasher did not drain water. The same water has been recycling from washing thru rinsing and sitting there after done.
Model: S62NXPLP-7624
Oct 03, 2008 | Dishwashers
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
350 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
