Question about Frigidaire FGX831C Top Load Stacked Washer / Dryer
Water level appears too low
We just enherited a Frigidaire stacked washer dryer combo. The washer does not appear to fill with water sufficiently. We end up having to add it manually. There is no water level switch, however there is a light/nornal/heavy switch which we have experimented with and seems to make no difference. Is this usually an expensive problem to fix? This is an older washer and we are debating whether to fix or replace. We prefer to fix if not too expensive. Thanks. BTW: the model is a LC-3 or LC8-3.
SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Posted on Nov 16, 2007
  • 2651 Answers
SOURCE: Washer and Dryer
there will always be water inside he machine(between the tubs, and in the hoses, but no so much to add that much weight so you cant move it, i would look to see of perhaps a levevling leg has hit the floor not allowing you to slide easily.
Posted on Dec 04, 2008
  • 1531 Answers
SOURCE: frigidaire stackable dryer/washer combo.. dryer on
the model number is located on the dryer door right as you open the door by the locking tab.need at little more clarity on your problem.
Posted on Jan 23, 2010
  • 1430 Answers
SOURCE: Frigidaire FEX831CS Top Load Stacked Washer won't
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Jun 03, 2010
  • 3361 Answers
SOURCE: Model FLXEC52RBS2 Frigidaire stacking washer/dryer. need
Copy and paste the link below for the Factory Service manual.
Posted on Sep 16, 2010
Why is water leaking from bottom of double stack fridgidaire washer/dryer combo?
Thank you for your post, friend!
From the information you have provided your Frigidaire laundry center is leaking water from the bottom after a day or so. It sounds like you have a slow leak and this could be in your drain line, drain pump, or gasket. I would advise you to review your gasket and drain hose to make sure there is no visible crack or wear that water could be leaking out of. If you do not see any apparent leaks it could be an issue internally and this is not a simply DIY job. You may need to request the assistance of a professional technician for proper disassembly of your laundry center. I hope this information has been helpful. -Matt
Feb 18, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
Top load washer will not fill with water. Doesn't matter what setting. Other functions appear to be working but no water.
Check to make sure you have power to the pump...if not, trace it back to the relay that kicks the pump on & see if the relay is energized.
Dec 18, 2013 | Frigidaire FGX831C Top Load Stacked Washer...
We have a frigidaire washer dryer combo. after a bad storm (our electric kept flickering off and on) our washer no longer works. we noticed that it would only fill up with water while dryer was on. now it...
Possible damage on the program control panel as it is most likely to be damaged due to a power outage. remove panel and check to confirm if the board is burnt or damaged
Jul 03, 2012 | Frigidaire FLEB8200DS Top Load Stacked...
It leaks water after its about half full does it have a hole in the tub?
I doubt if the tub has a hole in it, BUT the increased pressure and weight of the half filled tub could force water past a damaged washer. How did the washer get damaged, probably by the spin bearing starting to fail.
Items 21 and 26 are the parts that I would suspect.
Jul 20, 2011 | Frigidaire FEX831CS Top Load Stacked...
It won't hold water just keeps draining even while its filling. I bought a frigidaire stacked washer dryer and i just hooked it up today everything works great except when i turn it on it will work normal...
help is on it's way ... the drain hose needs to be 36 in high. . if it's too low it will drain and fill all day . you can use a drain ext. or longer hose if needed. if this does not correct problem / were still here . mm
Nov 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
I have a Plain Hotpoint washer,and it keeps filing with water on large load,but will stop on small load.Will continue to fill even with it unplugged, what could it be?
No it will not keep filling when it is unplugged.
The problem is probably due to a sticking water level switch, or a partial blockage in the water level sensing system. \you will probably need to call an engineer.
Dec 06, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer not filling
stuck pressure switch/water level switch also ckd for blocked or pinched hose to switch try taping water level switch possible stuck contact if this is case replace control wouldn't trust it not to do it again or worse overfill and fload
May 10, 2008 | Whirlpool LTE5243D Top Load Stacked...
Open Questions:
Frigidaire FGX831C Top Load Stacked Washer / Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
