Question about Janome Memory Craft 10000
False early signal indicates lower bobin empty when in-fact it still full contains adequate thread
Have a 1000 that has a persistent problem of indicating the lower bobbin being empty when in-fact it is still loaded with thread. Had it serviced with a change of what I suppose is the infrared sensor, nothing improved.  Can anyone help
  • Robert Brodie
    Robert Brodie Sep 05, 2008
    Its the Janome 10000 or course
  • Robert Brodie
    Regarding the seating of the bobbin how does one know that the bobbin is correctly seated. Is there a click or anything to indicate that the bobbin is well and truly in place correctly.
    Genius:
  • 1,269 Answers
Have you already performed a software/firmware update? If not, I suggests you to try it first.
Click HERE to download the updates
Posted on Sep 05, 2008
    President:
  • 1,263 Answers
It could be that once you had the sensor replaced that the fault was not reset in the machine. it could also be a loose connection. my suggestion would be to take the access covers off and remove all the dust as much as you can, then looke for the lose connection where the sensor was installed. look to see where the bobbin is seated make sure that it is seated like it should and that there is no dust in that area.. if this doesn't solve the issue it is a glitch in the circuit and needs to be serviced to resolve the issue....please rate this.....thanks
  • 19,396 Answers
If the sensor had been replaced already, it can onle be either a problem with the locic board or a mechanic fault.
Is the machine still under Guaranty?
  • Ginko
    Ginko Sep 05, 2008
    I know that sending back the machine for repairs again is annoying, but the usual cause for this problem is the sensor, if the sensor had just been replaced and is not working, it can be as result of a bad assemblyof the sensor on the machine, because the sensor is not well in place, or because the sensor has blown again, in this case there is a short or bad voltage on circuits powering the sensor.
    Therefore you need to send the machine back to inspect the sensor again, and see if anything concerning the last repair has gone wrong .
    If the sensor is ok it can be a problem with machine logic board, in this case check if machine is still under guaranty.
How do you thread the bobin
put an empty one on the bobbin winder and thread the machine to it . loosen hand wheel if required and use foot speed control to fill it .
Nov 16, 2016 | Sewing Machines
My problem is with the bobin. The machine worked well two days ago. Now when I try to sew , the bobin thread is becoming caught in the lower area and produces tension that stops the machine after about two...
With out looking at the machine it is hard to determine the exact problem, but make sure your bobbin thread is placed in the bobbine case corretly, and pulled through the little tension area on the bobbin case.
Next make sure the upper thread is in the tension discs, if not this can also cause you a problem, plus if possible used a little canned air (with the pressure foot up, machine unplugged and thread removed) blow out the tension area.
Good luck.
Mar 12, 2011 | Brother SE350 Mechanical Sewing Machine
The bobin thread is not feeding smoothly. The thread on the bottom of the material is bunching up. I have adjusted the tension in every which way that I can but the problem persists.
you might check & see if the thread has come off the thread take up lever
take the bobbin out of the case & then put it back in
also check the needle it could have a burr on it or be bent or blunt
Oct 26, 2010 | Janome Sewist 525S Mechanical Sewing...
How do I tighten the tension on the bobin thread I am quitiing with invisible thread on the top and dark blue on the bottom, the bobin thread shows. I don't want that
you can either increase the bottom tension or reduce the top tension .. you will notice a little screw on the bobin case ... that screw adjusts the force on a small flat spring which provides the bottom tension (the thread goes under the spring when properly threaded) .. .. tighten that screw a little to increase bottom tension .. you can pull thread thru the bobin case to get a feel for how much tension you have ... you dont have to turn the screw very far to make a significant difference .. try just 1/4 of a turn at a time .. remember where it was originally set so you can put it back when you are finished with your present project .. the greater the bottom tension the less bobin thread will show at the top ... if you get the tension too high then you might see some puckering as you sew ..
Jan 03, 2010 | Sewing Machines
Needle won't grab thread?
try threading the cotton through the other side of needle.
Oct 16, 2009 | Euro-Pro 7500XH Mechanical Sewing Machine
Needle not picking up bobbin thread. Seems threaded properly. lsd-1 (classic) Problem occurred after needle hit something perhaps the the cap spring which had some marks on it but no real damage. ...
change the needle, if bent it may skip, use top thread while holding to pull thru, turn bobin around to turn in oposite dirrection, bobins usually turn in 1 correct dirrection
Sep 28, 2009 | Sailrite Sewing Machines
Problem with the tension when embrod.
lower your top tension down, as it is tighter then your bobbin thread and also tighten your bobbin thread, this is done by the small screw on the bobbin holder, also you can try using the older metal bobbins these are the ones with the small holes around the top and bottom shank, but please make sure that they are the larger size bobbin, and only go very slow at first, try just in sewing mode first or just wind it over by hand.
Aug 12, 2009 | Janome Memory Craft 10000
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
I need to know the correct settings for the thread on my sewing machine. it bunches underneath
Thread bunching on the bottom almost always indicates that the thread is not sitting snugly between the upper tension disks or is out of the take-up lever.
  1. Make sure the upper tension is on a medium setting - generally 4 1/2 - 5 on the tension dial. If the upper tension is set correctly, continue with...
  2. Completely remove the thread from the thread path and start over, making sure the presser foot lifter is in the up position (this releases the tension disks allowing the thread to more easily position correctly).
  3. Once you've threaded the needle, lower the presser foot, making sure the thread tail is not under the foot but coming directly out of the needle eye.
  4. Give the thread a tug - if there's no tension on it, it's still not fully in the tension and needs to be "flossed"... grasp the thread tail with one hand and the thread just where it comes off the spool of thread with the other hand and floss it through the tension disks just as you'd floss your teeth. This will ensure that the thread is positioned correctly between the tension disks.
  5. If this still doesn't cure the "bunching", please provide some specifics about your machine - brand, model - and we'll do our best to figure out what's happening with your machine.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Jul 16, 2008 | Singer 3116 Simple
Sewing Machines Logo
54 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
