Question about Meade TeleStar 60AZ-A Telescope
Meade telestar D=130 mm F=1020 mm
I can not place scope on the fx position to glance at sky, Please help me
I just was given a Meade telestar computerized telescope d 130mm f1020 f/7.9 I'm wondering how much this is worth has everything with it. Great condition.
Posted on Mar 16, 2018
    Problem Solver:
  • 17 Answers
Rosores: make sure that the DEC clutch is not locked, and that the screw on the side bar is loose.
before pointing it upwards. or damage may occur.
Posted on Jun 28, 2011
Your website no longer contains the manual for the Telestar 114AZ model and I'm in desperate need of it's use.
This is a small reflector style telescope. Any of the REFLECTOR manuals has enough information to assemble and use this telescope. Look under the REFLECTOR heading for one that is similar to your scope.
Jul 07, 2011 | Meade TeleStar AZ-S Telescope
I need a manual for operating the Telestar DS-114. I want to teach my class how to use the computer driver.
All the manuals are on the Meade website here:
You can control a Meade scope using several different planetarium programs if you have the correct Meade cable.
Stellarium, and Cartes du Ciel both can control the scope. If you have a real serial port on your computer you can use the Meade cable and plug in to the bottom of the hand controller.
If your computer does not have serial ports then you must buy a USB to Serial adapter cable. Keyspan is a good brand.
Feb 11, 2011 | Meade 4.5" Telestar tonian Reflector...
I need to find an Eyepiece for my grandsons TeleStar 60AZ-A
Most telescopes use a standard size for eyepieces (one and a quarter inches outside diameter) and if that is the size of the mount in your scope, you can use any that fit. If you do a search on Amazon, you will find hundreds in this size, many of them branded Meade. The other dimension specified will be focal length. 5mm will give high magnification (but dimmer and harder to use) while 20mm will give lower magnification with brighter image and less fiddly focus.
Nov 15, 2010 | Meade TeleStar 60AZ-A Telescope
Received used scope and know squat!
Meade's website has manuals on most of their product - since they make hundreds of styles, an exact manual may not be available - just choose one that is closest. Things are inverted and reversed, as it is an astronomical telescope, and it does not matter what the orientation is when viewing the sky. To get the images part way corrected, use the diagonal mirror before the eyepiece and look in the downward position. images will be correct in the Up/Down direction, but not left/right. That is why binoculars have 2 prisms to correct the image.
Sep 19, 2009 | Meade TeleStar AZ-S Telescope
Where can I find instructions for the Meade 114 mm Autostar telescope
All of Meade's manuals are located here--
Jun 14, 2009 | Meade 4.5" Telestar tonian Reflector...
Manual For Telestar By Meade
Here are all of Meade's manuals ----
Dec 21, 2008 | Meade TeleStar DS-2114ATSA Telescope
Meade DS-2000 Manual Doesn't have info. about Meade Ds-2130
ds-2000 refers to the model line of the scope. ds-2130 the 130 refers to the diameter of the objective lens in mm. I have a ds-2114. Where the objective lens is 114 mm in diameter. as far as the manual goes everything else should be the same.
Dec 07, 2008 | Meade DS-2130ATS (250 x 127mm) Telescope
Meade etx-80 sticking
Some (not all) versions have an end stop - it it just reaching that? The scope will rotate only aboit 3 complete turns between the 2 ends.
The 'correct' starting position is as follows: Place scope on tripod or table with control panel at the West. Unlock the declination lock (horizontal slew). Rotate scope anticlockwise until it hits the end stop, Then roate it back clockwise until scope is pointing North (should be about 3/8 of a turn, as the end stop is at South West). Then lock the declination, Set the tube horizontal and continue with the alignment process.
Autostar always thinks you have set the position like that. If you haven't, it will work OK until it tries to rotate past the point it won't go, then chaos results!
Feb 12, 2008 | Meade ETX-90 (48x90 mm)
Meade TeleStar 60AZ-A Telescope Logo
1,231 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
