Question about GE JGRP17 Gas Single Oven
Gas stove My oven pilot is out and I want to know if I can re-light it safely without someone coming out?
  • 1,543 Answers
The JGRP17 (not a full model number) does not have a pilot light. It uses glow bar ignitors. Watch the burner at the top of your oven when you turn on broil. After a short time the glow bar ignitor begins to glow, and a short time after that the broiler burner should ignite. The same thing should happen with the oven burner under the floor of the oven when you attempt to bake. If the igniter does not glow, or glows and burner does not light, replace ignitor. (looks like part # WB2X9154)
Posted on Sep 04, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 06, 2008
    You listed your model as a JGRP17. If that is the model, the answer is correct. (a fixya) If you had the wrong model listed, don't rate me down for your error.
Hi The pilot light when out and the oven has stop working does the pilot light double as a fuse ?? BSO 6000
No. The pilot light uses a thermocouple(safety device) to let the main gas valve know that the pilot is lit so that the main gas valve can operate safely by not letting the main gas valve turn on without a lit pilot light. This way, in no way can the main gas valve turn on until the heat from the pilot light causes the thermocouple to produce an electrical current which allows the main gas valve to operate when the thermostat switch closes.
Nov 22, 2015 | Ovens
When you turn the temp knob the light will come on the panel but the oven will not light. Stove works fine. We have had this unit for 12 years. Thanks Bob.....
can you hear gas coming in when you turn the know to "ligth" if not the you may have either a bad gas valve or the safety feature has detected something wrong, and has shut the gas off to the oven. first determine if you do indeed have gas., how does the oven light, is it pilot lit, or does it have a glow plug, if its pilot lit, make sure the pilot is running. if its a glow plug, you should be able to see it glow when you turn the oven on, if its not glowing it has to be replaced (or maybe the wiring has gone bad). either way that's where to start.
Mar 19, 2011 | Ovens
Can light the oven pilot light but it won't stay on when I turn the dial to oven temperature. I cleaned the oven prior to this problem with spray on oven cleaner.
I have a 2003 maytag performa stove and i turn the oven on but sometimes it takes a while to come on and smells like gas so and lately i cant get the flames going. i see that the pilot glows but still know flame coming from tubes.
Sep 27, 2010 | Ovens
Stove works just fine/oven does not warm up - pilot light is on, but turning on oven does nothing but make the pilot light glow a little bigger. Oven will not ignite.
Hi, The ignitor is getting weak and will not open the gas valve. Replace the ignitor and you will be back in business. This is a very common problem with the gas ovens.
Please let me know if I can assist you further.
Vic
May 29, 2009 | Ovens
Propane not getting to oven... stove top works fine..
The pilot light must be lit and stay lit before you will have any propane coming into the oven. This is a safety feature.
May 17, 2009 | Magic Chef 9122 Gas Single Oven
Oven not working!
we're having the same problem.lol
Apr 10, 2009 | Kenmore Ovens
Pilot light
It was an electric ignition
Thank you
Nov 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Lighting pilot of GE gas stove
According to the model number you supplied it looks like your oven use a glow bar ignitor not a pilot light. In that case there is no place to hold a fire. what happens with these when you turn the oven on 120 volts goes to the ignitor causing it to heat up ,the amp draw across the ignitor causes the gas safety valve to open, and then lights the gas. So if you turn your oven on you should see a bright red glow if not probably the the ignitor, to check it you would have to verify you actually have power going to it. If the ignitor glows but the gas valve does not open you will still need to replace the ignitor has to pull about 3.2 amps across ignitor to open safety valve. Your broil burner works the same way. And most of the ovens the floor of the oven comes out to allow easier acess to the ignitor. also if you have to change the ignitor put just a dab of dish detergent on the screws to help from stripping them
Nov 27, 2007 | GE JGRP17 Gas Single Oven
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
GE JGRP17 Gas Single Oven Logo
225 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
