Spin Cycle is very loud on front load washing machine
It sounds like the main bearing on the tub of my washing machine is going bad. Is it possible to replace the bearing without replacing the entire tub? I took the large pulley and belt off and spun the bearing by hand to confirm that the noise is coming from the bearing.
  • Jerry Goggins Sep 04, 2008
    I certainly appreciate the quick response. Hopefully, it'll be relatively easy to replace the main bearing on the tub.
  • Anonymous Mar 14, 2014
    Can you tell me how I can get to the bearings on the Samsung front loading WF0602NXWG as I can only take off the top of the machine.
  • Washing Mach... Master
  • 19,396 Answers
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Posted on Sep 04, 2008
  • 3,037 Answers
Yes, you can, if you need a place to buy a new bearing, let me know the make and model and I will get you a link to purchase one from
Loud noises during spin cycle. Drum is eating up. All springs and shocks appear to be ok
The water seal has worn out and water has gotten into the bearings. You need to call a service tech to have it repaired. It is not a cheap repair. Whirlpool has a repair that replaces the back half of outer tub and a new inner tub or basket one in the same. Another salution is replace the seal and bearings, still a lot of labor. go to utube and a guy does to an LG, but the the repair is about the same for a Duet
Aug 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer is a Samsung WWF337AAW-XAC. Just prior to the spin cycle we hear a rattling or grating noise and then it rattles throughout the spin cycle. It will sometimes rattle at the end of the rinse cycle but...
hi Rick.
Reasons a washer will make noise during spin mode:
1. Main tub bearing faulty
2. Main drive pulley
3. Motor coupling worn
4. Bad clutch
5. Worn out drive belt
6. Clogged or damaged drain pump
7. Transmission is worn out
8. Shock absorber (front loader washers)
9. Springs or dampening straps (top load washers)
10. Agitator directional cogs aka "agitator dogs" (top load washers
When the washer spins, it rides on a bearing that allows the tub to move freely with zero resistance. If this bearing is worn out, a loud noise will be heard when the washer spins. A good way to tell if your washer problem is the main tub bearing will be that the washer noise will get worse or louder as time goes on. This means the bearing is becoming more worn out and close to complete failure. The bearing in your washing machine is a circular metal object that has many small little metal balls inside. These small metal balls inside the bearing sit in a track and move when the washer is spinning. If the tub bearing begins to wear out, usually the small metal balls inside can fall out one by one causing the noise you hear. (If your washing machine is a front load washer, open the door and turn the drum by hand. If you hear a rubbing sound or the drum spins uneven, then the main tub bearing is most likely bad and needs replaced.)
Washing machine tub bearing
Washer has noise during spin cycle
The bearing may also be without lubrication. If the sound you hear is more of a squeaking noise than a grinding noise, it may mean the bearing needs to be lubricated with a mechanical grease. If the sound is more of a grinding noise, then this usually means the bearing is falling apart and will need to be replaced ASAP. If you suspect your washers main tub bearing is worn out, the repair process is one of the most difficult to perform yourself. A worn bearing can also damage the tub of the washer. This means the tub (inner or outer) may need to be replaced also.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to your washer) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose. To find out if the drive pulley is causing the noise, you will need to take the washer apart and inspect the pulley for signs of damage.
WASHER MOTOR PULLEY
The motor coupling could also be the cause of the loud noise. The motor coupling in your washer connects the washers transmission to the motor. It is made of plastic and built to break if the washer gets overloaded. This is so the motor and the transmission do not become damaged. The motor coupling is an easier repair and can be done by most people.
Washer Washing Machine Motor Drive Coupling Coupler
The clutch in a washing machine connects the inner wash tub to the transmission. The clutch lets the washer get to the proper spin RPM in a gradual way. If the clutch is worn it can make noise when the washer is spinning. A bad clutch needs to be removed and replaced to stop the noise.
Washing Machine Clutch
The belt in your washer can become worn and cause noise while spinning. If worn out, replace the belt. Replacing the drive belt on a washing machine is an easy task and can be ordered online for less.
Washing machine belt
The drain pump in your washer that drains the water out could be clogged or damaged. While in spin mode, your washer may drain out the water by using the drain pump. If the loud noise only happens at certain intervals during the spin cycle, it may be the drain pump. Usually this can be fixed by simply removing the drain pump and removing any debris that may be clogging it up causing the noise.
Drain Pump for Washing Machine
The next part of your washer that can be causing a loud noise is the transmission. If the transmission is bad, usually the cost to fix this outweighs the cost of a new washer.
If you have a front loading washing machine, they all have shock absorbers. The shock absorbers are used to center the tub movement while in the spin cycle. These shock absorbers are connected from the washer frame to the outer tub. If the shock absorbers in your front loader become weak the washer will make a loud banging sound during the spinning cycle.
Shock Absorber for washing machine
Top load washers usually have springs or dampening straps holding the tub centered. If a spring or strap falls off or becomes weak, a loud noise will be heard in spin mode. Simply replace the strap, spring, or springs to remedy this issue.
Washing machine suspension springs
Agitator directional cogs are used to operate the upper part of dual action agitators (Top load washers). They engage the cogs on the inner area of the agitator as it turns in one direction. They release when the agitator reverses its direction. This lets the top part of the agitator to ratchet in only one direction. The bottom part will agitate in both directions. The cogs are made of plastic and wear out with regular use. They will start slipping and make a grinding noise. Another way to be sure that this part is bad is if you notice the top portion of the agitator does not move in a smooth motion. Removing the top half of the agitator to see if the cogs are worn out.
Dec 08, 2017 | Washing Machines
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
During the spin cycle the front load washer makes a loud noise. Sounds like a bearing going bad.
you got it,and the whole tub has to be replaced because it's all one piece-mike
Jun 30, 2009 | Kenmore 44072 Front Load Washer
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Washing Machines Logo
1,772 people viewed this question
Top Washing Machines Experts
