Question about Itochu C.itoh CI 5000 Matrix Printer
A21 Home Error
Checked the fuse. Still good. Any other ideas on what it could be?
drifterK
  • 4924 Answers
SOURCE: citoh ci 5000 giving a
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
If this will not fix it ..it means that the issue is mechanical and this will explain the second error ..and the mechanical thing will be on the motor that drives the print head..
Posted on Sep 29, 2010
Where can i get PC suite for karbonn A21 ?
please send the karbonn A 21 pc suite
Nov 28, 2012 | Cell Phones
2009 ford edge sattelite radio shows 'fault' on screen
all controls to my radio are dead, not even showing the time. I've checked the fuses and all are good, any ideas?
Dec 11, 2010 | Sirius Satellite Radio Receiver
Acer monitor will not work, not light no
The capacitors are good, no bulging top/seal? Pictures? see example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Pictures will help a lot.
Mar 19, 2010 | Acer AL1914 19" LCD Monitor
Pride celebrity XL won't go.
Have you checked the motor brushes for wear and spring tension, sometimes the spring becomes brittle and breaks but can sometimes still make contact.
Regards Steve.
Sep 01, 2009 | Drive Medical Mini Phantom Three Wheel...
IBM thinkpad A21 won't start up
1# remove the battery from the thinkpad and ac adapter.
2# hold the power button for 40 seconds.
3# plug in the ac adapter and turn on the botton.
4# see it for works what trying to do to thinkpad is recyle the power .
give it a try and see if it work if it doesnt let me know
Nass
Apr 14, 2009 | IBM ThinkPad T21 Notebook
Error code A21
Aug 30, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Home Error
Apr 02, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
37 people viewed this question
Top Itochu Office Equipment & Supplies Experts
k24674
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
