Question about Acer Computers & Internet
Can't find my wireless card
Can't find my wireless network card
  • andrew pester
    andrew pester May 11, 2010
    you mean you are trying to locate it or trying to connect to the router?
    President:
  • 2,961 Answers
Assume you found it
Posted on Sep 05, 2008
How do i download network adapter for my dell tower, its service tag is C0WST21
please page the URL below in your browser and click download button.
http://download.cnet.com/Network-Dell-Wireless-US-WLAN-Network-Adapter-Card-Wireless-1370-802-11-b-g-WLAN-MiniPCI-Card-Wireless-1350-802-11b-g-WLAN-miniPCI-Card-Wireless-1450-802-11a-b-g-Dual-Band-WLAN-miniPCI-Card-Wireless-1350-WLAN-802-11b-g-PC-Card-TrueMobile-14/3000-2112_4-109107.html
Feb 19, 2011 | Dell 04U852 Network Adapter
Where is switch on dell latitude e6400 to enable wireless internet access?
hi
go to this link, review
What You Need to Establish a WLAN Connection http://support.dell.com/support/edocs/systems/ins6400/en/om/network.htm#wp1052373
  1. Click the Start button, point to Settings, and then click Control Panel.
  2. Double-click Network Connections.
  3. Right-click the Wireless Network Connection icon, and then click View Available Wireless Networks.
If the Choose a wireless network window states Windows cannot configure this connection, the wireless network card's configuration utility is managing the wireless network card.
If the Choose a wireless network window states Click an item in the list below to connect to a wireless network in range or to get more information, the Windows XP operating system is managing the wireless network card.
Dec 01, 2010 | Dell Latitude E6400 Notebook
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
Change wireless network name, how and where?
The wireless network name is defined by the router (access point), not your individual wireless card (bridge). The manual for your wireless router will tell you how to change the name of your wireless network.
Nov 17, 2009 | Computers & Internet
Laptop states wireless adapter not installed and configured? worked before.
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
Oct 11, 2009 | Gateway (802.11usb) Wireless Adapter
Wireless not working
First make sure the Wireless LAN card driver is installed. Then go to device manager and make sure the Wireless LAN card is enabled. If not, right click on the Wireless LAN card icon and select enable. Once that is done you should be able to search for wireless networks. If a wireless router is not broadcasting the SSID for the wireless network, the Wireless LAN card will not be able to locate the network during the search. If that is the case, you will need to set up the connection manually. If you can see the correct wireless network during the search but still can't connect to the network, it may not be an open network, so make sure you have the correct security settings for the network you want to connect to. If you did not set up the wireless network, you will need to get the security information from the network administrator.
Jun 10, 2008 | Everex StepNote NC1500 Notebook
Belkin mimo G network card
I think in your Pc Wireless lancard is disable,Pls enable the wireless lancard,
1. just check the lan card is enbled
example:my network place --right click---properties---wireless lan card,
2. check the R u getting ip address,
example: start---run---cmd----ipconfig
May 20, 2008 | Belkin Dual-Band Wireless A+G Desktop...
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
