Can't install without bugging. Software more than shitty. How can Panasonic sell videocams without thinking about and solving all these problems ? I'm not even hoping to get a solution, as I also had to renounce to their AVCHD cam because it's almost impossible to edit AVCHD films in good conditions. So far and maybe to help, if you have a"more advanced Adobe Reader 8.", just explore and initiate the VideoCam suite set up and not the automatic set up so as to bypass Adobe Reader ; hoping that your system is compatible (that is, not XP SP3 or VISTA SP1) When are they going to replace that **** , That's the real problem, as they meanwhile seem to be possessive and jealous about their poor and buggy software ! As to me, I had to install the bog/bug on my second hard disk (XP SP2) Good luck to everybody and If you have a solution, disabuse me.
-   my os is xp-sp3 it can't send files to pc normally-   Guest
Dec 11, 2008
-   I have the same problem, VideoCam suite incompatible with Vista. Has anybody found solution (except using another OS or camera)? -   mireks
Dec 08, 2008
-   I have XP service pack 3 and will not work-   Guest
Dec 04, 2008
-   I had the same problem with vista SP1. I had to boot in safe mode to fix it.
-   Guest
Nov 02, 2008
-   I have the same problem - the software continues to shut down. I am very unhappy with this and would NEVER buy another product;.
-   Guest
I am having the same problem as www_ccowell. I have a SDR-H80. The supplied USB doesn't seem to be...
(More)
I am having the same problem as www_ccowell. I have a SDR-H80. The supplied USB doesn't seem to be recognised by my MacBook Pro. It's not popping up anywhere and when I plug the cable into the recorder - it doesn't have any power.
I have a panasonic TM10 camcorder - every time I try to burn recorded footage on to a disc the...
(More)
I have a panasonic TM10 camcorder - every time I try to burn recorded footage on to a disc the software crashes (gets about 10% in to the burn). Any suggestions how I can get round this? Cheers Richard Dennett
