Question about Equinox EMS1000T-001
Need schematics for this board know of where I can get them
    President:
  • 1,734 Answers
Check here, they are schematic finding experts
Posted on Jun 30, 2009
I'm Ziro. I need a part list for the main power supply board for behringer pmp4000 mixer, two transistors were removed from it and I need to know the part numbers of each in order to install them.
In my opinion, due to the physical appearance of pmp4000 and pmp3000 look the same, it will most likely also have a common circuit and parts list (at least, most).
Usually Behringer (and all the manufacturers), with the same series / sequence, using the same circuit, the difference is the number of channels only. You can compare the parts list on PMP3000 schematic, with your PMP4000.
PMP4000.
PMP3000
You can download from this link.
http://elektrotanya.com/behringer_pmp3000_sch.rar/download.html
Hope this helps.
Regards.
Oct 05, 2015 | Behringer Music
My paper shredder, Royal 15 mx does not go in reverse. Opened unit and know circuit is getting power since led light goes on. I believe the issue is with the circuit board which is not acting as a...
Dont know if even Royal will have a schematic for the PCB,...most of these are "replace/throw away" pcb's in consumer machines...anyway you can contact Royal at 1-800-524-0799 and see what they say.
Nov 06, 2010 | Royal 15MX Shredder
Hi, I need schematic diagram for IP-48135 T board....
The schematic diagram is going to be very hard to get. We do repairs on this model. What information do you need? The most common problem is the capacitors on the power board. You can find this repair guide at: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ If you need other information then let us know at: tech@ccl-la.com and we will get glad to assist you in the repair.
CCL_Tech
Corporate Computer
www.ccl-la.com
May 21, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Hum no audio output
There are a lot of folks who've had power supply issues with this sub. Typically, the large resistors fail, which takes out the capacitors.
If you know how to read schematics and replace parts, then these might be helpful to you:
Here are the two pages of schematics from KLH. I wrote to their tech department and explicitly asked for permission to share them here.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
Dec 22, 2009 | KLH ASW10-120 Subwoofer
How do I fix a blown amp
big red
check usually the fuse just blows up just change it
Oct 22, 2009 | KLH ASW10-120 Subwoofer
No power
All lights come on HP Pavilion dv1000 but will not boot. looked at motherboard and by power connector there is a blown part the number on the board shows PD27. I need to know what thhe part is or a schematic showing
Jun 23, 2008 | HP Pavilion dv1000 Notebook
Green start light turns red and blinks 6 times. Is this a transformer problem? If so, do you know a part number and/or place to purchase the part?
The problem you have is with the G1 board. The 17 volts is not supplied. Do you have a multimeter and know how to trouble shott following a service manual schematic? if not call a pro to assist you as this could be the G1 board, but to be sure, you will need to troubleshoot and check some voltages and follow circuit flow using a schematic diagram. If you do know how to read, analize and follow schematics schematics contact me at techman32k@yahoo.com. If you do not, take the set to an authorized Sony repair center. Good Luck
Sep 18, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 57h82 replacing caps on hyper board
trace them with a continunity meter and all will be ok...
Sep 17, 2007 | Toshiba 57H82 57" Rear Projection...
Equinox EMS1000T-001 Logo
44 people viewed this question
Top Equinox Televison & Video Experts
Electro Med Services...
Are you an Equinox Televison and Video Expert? Answer questions, earn points and help others
