Question about Sony Ericsson Walkman W810i Cellular Phone
Saving camera images
My sonyw810i will not store images taken with the camera since ive had the volume button fixed.It stores them in panarama mode and in frame mode but not in normal and burst mode
  • Simon Emma
    Simon Emma Sep 04, 2008
    I have tried updating the firmware, the software and reset the mobile with master reset , but this problem still persists , could the repair that was done to the volume key have caused this problem ?
                 This problem was not there before I had the volume key fixed.. This shows how you cant cut corners when having your mobile repaired..
                           I took it to an amateur technician and now I have this problem, very annoying ...as they took my money and then my mobile is returned to me with a more serious fault than it had before..
            Beware !!! of those who can fix your mobile very quickly , this technician has obviously not replaced the volume key but has jammed paper or kitchen foil under the key contacts to make it work and charged me 25 UK pounds for it...
    Brigadier General:
  • 7,752 Answers
What you can do not is have the firmware the original one that is reflash on the phone also if the tech has upgraded the phone to CID53 instead of CID52 it would be very hard to change it back to CID52 unless you do it online at topsony.com
Posted on Sep 13, 2008
What are the buton combonations for the factory reset on an android tablet
There are few combinations and you'll have to be quick to get the moment to press all 3 at once. Don't work every time as you have only a second or less to press the correct combination:
Each phone manufacturer has its own Recovery Mode key combinations.
You'll have to try each combination until you find the correct one for your Android phone or Tablet.
* Combination 1 - Volume Up + Camera button.
* Combination 2 - Volume Down + Power button.
* Combination 3 - Volume Up + Power button.
* Combination 4 - Volume Up + Home + Power button.
* Combination 5 - Volume Down + Volume Up + Power button.
* Combination 6 - Home + Camera button.
* Combination 7 - Home + Power button
Nov 29, 2017 | Tablets & eReaders
How do i clear the internal memory from my camera. on the scean it says internal memory full
The M530 has 32 MB of internal memory, 20 MB of which can be used to store images. You delete images the same way you would if they were stored on an SD/SDHC card. Take out the SD/SDHC card if one is present (so you don't delete images on the card) and turn on the camera in Review mode (press the right-facing arrow button). Use the arrows to move forward and backward in the image list. Press the Delete button to delete them and free up the internal memory.
Hope this helps!
Mar 02, 2011 | Kodak EasyShare M530 Digital Camera
Photo shots: the pictures look as if a super flash wash used, even when flash is not used. Movies are o.k.
It is problem of ccd imager chip in DSC-T1 camera that gives you washed out still image after taking shot/ stored image, you may get live view correct in camera mode and movie but it saves taken still picture over bright etc.
Replace ccd imager chip by local camera repair shop to solve this issue.
Thanks.
Nov 16, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
My Fuji FinePix S5000 has given me years of excelent service. While on break I stored the camera for 2-3 months. When I pulled it out I noticed I had inadvertantly stored it in the "playback" mode. It was...
Have you tried removing the actual lens(?) to see if there's something inside the camera house that's not supposed to be there. I'd find it highly unlikely that the, thou who knows. The best thing to do, would be to drop it off at your local camera repair-store.
Jul 29, 2010 | Fuji FinePix S5000 Digital Camera
The display screen is blocked. The lens is open. Can see outline of blockage
If Canon A70 camera shows previously taken/ stored pictures properly in playback mode and does not show live view in LCD in camera mode to take fresh pictures then it is ccd imager chip failure problem and ccd imager chip will be replaced.
Canon offers free of cost repair for A70 for ccd imager failure problem. Click Canon CCD Imager Advisory for details.
Oct 23, 2009 | Canon PowerShot A70 Digital Camera
I dont have my manual with me .Could you please tell me how I view the 'photo that I have just taken on my Samsung S630
■ If the memory card is inserted in the camera, all the camera functions apply only
to the memory card.
■ If the memory card is not inserted in the camera, all the camera functions apply
only to the internal memory.
■ If you have turned on the camera by pressing the POWER button, you can press
the PLAY MODE button once to switch to Play mode and press it again to switch
to Recording mode.
■ You can turn the power on with the play mode button. The camera is turned on in
play mode. Press the play mode button again and the camera will be turned off.
■ You can set up the PLAY mode function by using the camera buttons and LCD
monitor.
2. The last image stored on the memory is
displayed on the LCD monitor.
● Playing back a still image
1. Select the PLAY mode by pressing the
play mode button ( ).
100-0007
3. Select an image that you want to play back
by pressing the LEFT / RIGHT button.
※ Press and hold the Left or Right button to
fast forward the images played.
AND here is the manual in free downloadable form
http://www.fixyourownprinter.com/forums/inkjet/24191
Oct 09, 2009 | Samsung Digimax S630 Digital Camera
When i go 2 photo,s ive taken.then move the shutter button 2 the right 2 zoom in,then it lets me move the picture up down left or right.when ive got the picture i want,how do i save that picture.
Unfortunately that image is not able to be saved that way. To zoom in closer to the image is only for viewing purposes it does not allow you to save the image that way. You would need to download the image to the computer to be able to save it in that close up format.
Feb 24, 2009 | Olympus FE-330 Digital Camera
Loss of manual
Please call Jazz Products @ 732-572-7050
Dec 05, 2007 | Jazz JDC31 Digital Camera
Lost Images
You may have possibly partially transferred images to the computer - are they anywhere to be found? You may have whilst taking images altered the resolution setting thus reducing the capacity of the card. Download this and run the memory card through it it will pull up any missing images. www.pcinspector.com or www.konvar.com downd load the program, install it and direct it to the plugged in camera in the download mode. Also get hold of a card reader, saves on batteries and this sort of problem
Jun 01, 2007 | Sony Cyber-Shot DSC-P32 Digital Camera
Sony Ericsson Walkman W810i Cellular Phone Logo
35 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
