Question about Whirlpool GEW9200L Electric Dryer
Duet Dryer vent re-routing
The procedure to re-route the vent from the rear to the left side.
  • 2 more comments
  • pati65 Nov 19, 2008
    I'd like to move the vent on the Whirlpool Duet dryer (model # YGEW9250PWG) from the rear to the side.The manual accompanying the appliance doesn't explain how to move the vent but
    just says to call the dealer for service. Can anyone comment on the
    complexity of the procedure?
    Thanks
  • richathome Dec 26, 2008
    good question... I'm in the same boat with a 9300 model.
  • Anonymous Dec 31, 2008
    The instructions in the manual do not tell you how to install the side mount.
  • Anonymous Mar 23, 2009
    yeah, i called the seller who told me to call whirlpool...whirpool told me to call the seller...who then told me to call whirpool back....who then told me to "find someone in the yellow pages who can help" ... their techs will not move it...only fix it if it breaks....guess once the check is cashed you become invisible to whirlpool, good luck!!!
  • 750 Answers
Dear sbrown183,
Welcome to fixya,
You asked for the procedure to re-route the vent from the rear to the left side.
Here below are the instruction you requested for venting both the rear and or the sides.
If you follow these manufactures directions and you will be fine
You will find them on pages 11, 12 and 13.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208533582.pdf
Let me know how you do.
Please remember to leave a solved rating!
Thanks for using fixya
Huuum
Posted on Oct 10, 2008
Hmm...I've read the manual, you directed the person to instructions which basically say,
Step 1: pick up telephone
Step 2: call whirlpool dealer
Step 3: shedule dealer to convert vent option
Helpful!
"Optional exhaust installations
This dryer can be converted to exhaust out the right side, left
side, or through the bottom. Contact your local dealer to have the
dryer converted."
Posted on Nov 02, 2008
Want to side mount dryer vent hose.
There should be what is called a knock-out panel on the side of the cabinet that is 4 inches in diameter... then you need the adapter kit to route the exhaust 90 degrees to the side... https://www.google.com/aclk?sa=l&ai=DChcSEwicp73NkufPAhWFMWkKHYu9BWsYABAT&sig=AOD64_1Cjzub4z0RkLpGJ6plZANoOKacbA&ctype=5&q=&ved=0ahUKEwjbsbjNkufPAhUo8IMKHU0cANsQvhcIMA&adurl=
Oct 15, 2016 | Maytag Dryers
I cannot located the answer to question, where the grounds connections on 2005 Aveo ls how name are they
G101
Under the ECM
Harness Routing Views
G102
Behind the left headlamp to left of battery
Harness Routing Views --
G103
On starter mounting bolt
G104
Behind the right headlamp under air cleaner
G105
On the engine block, near the starter
G201
Behind the left side of the ashtray
G202
Behind the right side of the ashtray
G301
Behind the passenger kick panel
G401 - Hatchback
On the left side of the rear compartment panel
G401 - Notchback
G402 - Hatchback
On the right side of the rear compartment panel
G402 - Notchback
In the rear compartment, on the rear panel next to the deck lid striker
Oct 18, 2015 | Chevrolet Cars & Trucks
Softtronic t8303 the machine stops when drying clothes after about 1 minute and the alarm goes off until the machine is shut down. When i try to start the machine with no clothes in, it keeps going till...
One possibility could be that you have a clogged LINT DUCT VENT to the outside.
It sounds like the damp sensor is working fine as when your unit senses no moisture, it shuts off. Soooooo, if the LINT DUCT VENT is partially clogged somewhere between the dryer tub and the outside of the house, then the sensor is sensing too much heat because the air flow is limited terribly somewhere. Take your entire LINT DUCT TUBING and clean it completely. Also, make sure you do not have any loops or droops in the whole ducting route. Make sure the lint duct tubing is not having to blow uphill anywhere in its route to the outside of the house. Dryers can not blow damp lint up hill very well and when folks try to make a dryer do this, the dryer will try, but damp lint will collect in a low spot, or in a hose route that has too many turns in it to the outside. Make the route of the hose LEVEL and even downward if possible. If it is a good idea to vent the hose out the side of the dryer, (to reduce turns, - remember they are death in a dryer) if possilbe. Not all dryers allow this. Look in your users manual for any suggestions.
kindly,
Jim
Oct 15, 2013 | Miele Dryers
We have a gas dryer whipool duet . It dry the towel but it still litle damp and the flame it good , no vent hook up , and it run for 70 minute cycle ,. Any idea why that happen . Please hepl
If you are not venting the moisture from the towels away from the rear of the dryer that could be causing your problem. If the dryer is up against the wall try either moving it away from the wall or hooking a vent hose to the discharge and at least pulling the other end of the host around to the side of the dryer. The dryer pulls air into it self from the rear and bottom of the dryer so it could be pulling the moisture from the towels right back into the dryer making it take longer to dry. Hope that helps
Aug 29, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a Whirlpool Calypso gas dryer, vented in the back. Can the venting be changed to vent out the side?
some dryers have a round "knockout" on either side which would allow for different venting options. You also need to check the ducting inside the machine to determine if it can be re routed without causing a sharp bend or kink that would cause over heating and lower efficiency.
Apr 30, 2011 | Whirlpool Dryers
Can exhaust vent come out of the side of the dryer?
It has to come out of the hole made for the exhaust hose to connect to. After that it can be routed anywhere that's not in the way of the operation of the dryer and to the outside.
Jan 25, 2011 | Samsung DV337 Electric Dryer
How do I route a new belt?
From the rear of the dryer the back of the belt has to be on the right side of the idler pulley, then around the motor pulley. If the back of the belt is against the left side of the pulley looking from the rear the belt will be too long, not enough tension.
Nov 25, 2010 | Amana NDE5800AY Electric Dryer
Can't get belt on dryer properly
The routing for the belt should be on a diagram somewhere inside the dryer. It sounds like the belt is not properly routed around the idler/tensioner pulley -- this is a very tricky routing -- without a diagram, it's a bunch of trial and error. Can you find the routing diagram?
Apr 22, 2009 | Dryers
Kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
Jun 06, 2008 | Kenmore 62822 Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
3,710 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
